Hey Guys,
Just got a boost gauge installed and want to check the numbers....
The truck is basically stock (motor wise) with just over 240 000 Kms on it. The only mods are a Pyro, and a "power" metering rod in the fuel pump.
mild acceleration peaks at around 7psi
moderate and hard acceleration peaks at 10psi
It has not exceed 10psi in the couple of days I have had it on.
Cruising at 50 Km/h 0psi
Cruising at 80 Km/h 2psi
Haven't been on the highway yet, so I don't have a reading for anything higher.
Do these look right?????
Also, I am thinking about adding a manual boost controller to get me a few more psi, and a bit more hp (and for $70 to $100, it appears to be cheep hp)... Don't worry I'm not trying to make it a drag truck, but a bit more passing power would really be nice! That and the "power" metering rod claims that it will work much better with more boost.
So the question is, what is the stock turbo capable of? I was thinking just a couple more psi like 13 or 14 would be a huge improvement without killing the turbo. What is the life span of the average turbo? Seeing how I'm pushing 250 000 km's am I nearing the end of it's life span? I did check the shaft for play about 20,000 km's ago and everything seemed fine, no more than a couple thousandths play.
Anyone out there running a controller????
Thanks again,
James
Thanks again,
James
