Difficulty of adding a boost compensator-1HZ
Japan
I have read several threads and understand the process but I’m looking for honest opinions on how difficult it is to add a boost compensator to my 1HZ IP?
-Tools you wish you had or would help complete it.
-Parts that made you run to the auto parts store because you didn’t have it.
-difficulties you had that made a 2 hour job turn into a 4 day job.
Would like to tackle it this weekend over my 3 days off but I’m a one-man-band with the closes parts store 40min away.
Thanks
Since your thread has sat unanswered, I thought I'd give you a little help, even though it won't be enough.
If you have the flat top pump right now, without the high alt comp top-hat on it, you can check my thread here and at least get some info for removal of the original cover... It can be done in place, but is a royal pain.
Once you get your BC top ready to go on though, someone else will need to tag in...
Post in thread 'High altitude compensator 1HZ retrofit?' High altitude compensator 1HZ retrofit? - https://forum.ih8mud.com/threads/high-altitude-compensator-1hz-retrofit.1251575/post-14660870
This might be help to get started though?
