Boneyard Finds
2016 4Runner at the UPull with Eibach suspension/ lift. I'll post pictures when I get home.
Pics.
Left front.
Right front.
Left rear.
Right rear. Appears to be leaking.
Front up close.
i think i can use that rear diff but looks like it's been pulled already
I didn't look. I thought it was still there.
Ya know, I'm almost positive it was still there.
Yes, but ... the right side was still installed.
That lift is good score for junk yard prices I would expect.
This 2016 is a rear diff lock axle, but I think the actual housing might be slightly bent due to the collision on passenger rear corner. The LCA is bent, and some of the welding on that side of the axle housing looks suspect now. The LCA was bent due to the rear axle getting pushed forward on the passenger side. However, I bet the axles themselves are completely straight.
The third number is still inside the axle housing.
I would grab the front coil spring start combo, as well as the UCAs. I can use the front CV axle but I didn't bring the appropriate tools. Also, the transfer case and transmission is ready to be grabbed by somebody since they're already sitting loose in the engine bay after they pull the engine out.
Front and rear suspension comes with KDSS and everything is complete intact as of today.
I grabbed the rear springs and shocks, oh
and the front LCA skid plates.😁
