Does anyone still actually make a set of 12mm body lift pucks? Not looking to get them made if I can buy them.
Thanks!
Thanks!
Geez, that is so simple that it is genius. Nevermind, figured there was more to it than that.
There is a thread on here where @spressomon gives some good details, just tried finding it but no luck. I'll keep searching around. You may also need longer bolts, but I'm not positive. I think anything bigger than 1/2" (~12mm) you start running into other problems with fan hitting the shroud and weird steering issuesGeez, that is so simple is genius. Nevermind, figured there was more to it than that.![]()
Generally installation of a 12mm/1/2" nominal body lift on the UZJ100 doesn't require modification of the radiator mounts/fan shroud and/or the t-case shifter. From my install all body bolts had adequate threads to accommodate the 12mm/1/2" body lift pucks. I think 4 of the bolts ended up being just barely long enough. Loctite (242 minimum) or utilize the longer OEM body mount bolts from other body mount locations (IIRC there are 4 different lengths of body mount bolts on this platform).
Having said that, the rear most body mount bolts get rust corroded in short time due to their location relative to road debris that gets kicked up to their location from both front and rear tires, and need to be replaced anyway.
The "J" bolts, located between the 2nd and 3rd seat rows, offered enough adjustment/flex to accommodate the 12mm/1/2" pucks on my truck.
Easy enough to inspect your specific truck's body mount bolt threads to determine if the existing bolts have adequate length threads.
Spesso- did you only lift 1/2"?
I am trying to decide if i want to do a body lift to help clear my 35s or if I am better off dropping back down to a 33.5" tire. FWIW, I am running OME 2.5" lift and 864's out back.
Thanks for the great advice! Is there a thread for your 1" body lift fab? Would like to know what mods are involved.I originally started with the 12mm body lift but later fabbed the 1" BL set-up I currently run to gain additional front tire compression clearance as well as a little more compression clearance for the rear suspension for my <then>baja/prerunner style off-road rally pretends
In answer to your tire size question: Always run the smallest tire you need; especially on the UZJ100 platform.
Also, would like to credit @wildsmith as I believe he was the first to install a body lift (1.6" IIRC) so he could run 36" swamper style tires.
@spressomon
Dan, how much lift did you end up with overall? What size tire did you end up running? With the 1" BL did you gain full stuff at full lock? I have a block of 6061 T6 3" aluminum rod that I am going to have a machinist friend chop into hockey pucks for me, I am just trying to decide just how thick to cut them. I was leaning towards 1" but don't really want to jump on a slippery slope of linkages and steering issues. Thoughts?
I might recommend HDPE or similar over aluminum for the pucks. My aluminum pucks squeak as the body weight shifts around on top of the frame. I am thinking HDPE would not have the same issue.
Did you ever pull the trigger? I am debating whether or not I should try and do a .5" BL before 100's in the hills this year...Interesting, I hate squeeks so I will look into this, thanks for the heads up.
I got the TrailTaylor 1inch body lift and I like the results.
