gash05
Well the day had finally arrived. I was attempting to start my brand new rebuilt 72 F engine in old Sweet Pea. I had topped of the coolant through a brand new 3 core radiator, new hoses, water pump etc. yesterday. I had topped it off several times throughout the day yesterday as I found leaks, air escaped, my heater core leaked like a sieve etc. Anyway, back to the point. The old girl fired right up and I was adjusting the idle on the newly rebuilt carb when the freeze plug on the back of the block above the bellhousing blew out with a good bit of pressure.
I'm pretty sure that the fluid was not scallding hot as it didn't really burn my eyes, nose, mouth and face as it sprayed all up in them. She had probably run about 5-7 minutes and while I didn't look at temp gauge I figure she was probably about to crack open the 190 degree thermostat. I am at a little bit of a loss as to whether the freeze plug was not installed correctly at the machine shop or if it could possibly be that the radiator cap (either 13 or 16 pounds not quite sure) held too much pressure on the system or something else. The freeze plug has black silicone type substance on the back of it and a dent about the size of a dime in the convex front side. Any thoughts?
