I have a 79 with 2F, 38 webber. The carb was installed about three years ago at the same time the head was replaced. The rig has run great since the work was complete. I only drive it in the summer - seasonal permit. I went to fire it up for the first time in March and it would rev up then die out, rev up and die out but never idle smoothly. Pulled the filter on the carb, found a few tiny specs, cleaned it out (filter). She fired right up. I let it idle for 10 minutes or so and shut it off. A few days later I tried to take it for a spin but the erratic idling started. Pulled the filter again, found one small spec. Same bad idle. So I drained all the fuel and replaced the filter since it has sat for a few months. No improvement. Pulled the valve cover, all valves seem to be moving, checked clearances , all ok. Took apart carb, was almost spotless, cleaned anyway. Now it wont idle at all. It pops right off, revs up once, then blows fuel out of the carb. Not sure where to look next. The cruiser has always fired right up and ran great the last time i drove it.
Dan
Dan
