I just went through this process fitting an older style Kaymar which came off a troopy onto my BJ74.
First thing is the side brackets extend a long way down the side of the rail, which may be fine on a troopy but fouls with the rear shackle hangers on the BJ74. So I cut them off somewhere behind the shackle hangers with the intent that I'll come up with some replacement for the removed bits at some point in the future. Next issue was there was a slight difference (10-12mm?) between the vertical locations of the bolt patterns on the ends of the rail versus the 'pintle hook' bolt pattern in the centre of the end-of-frame crossmember. I ended up plug welding and re-drilling the holes in the kaymar which bolt up on the ends of the chassis rails, was a bit of a pain but well worth it.
