Good morning Wayne.
crushers said:
so i am sitting here in my flu induced, drug induced early morning state , trying to understand why you are pointing towards a difference.
Because saying you have exceeded the stock parameters and need to make adjustments (either design or driving style) is totally different then creating blanket statements that something is designed or engineered wrong because it is not working for you. There is a huge difference in those two perspectives, and can mis-inform the masses.
crushers said:
now if the fix fan can "mask" problems then why not the clutch fan?
Yes, the clutch fan could as well in fact mask a cooling system fault. It can engage more then would be required if the cooling system is marginal and/or impaired for some reason.
I think if both your old HZJ75 and Goldboys BJ74 both have fully functional coolant systems, (each component is operating correctly to spec) and you are both hitting the redline…then you are loading/or have tweaked the engines output past the design point of the stock cooling system. There is nothing wrong with that if that is the load you choose to place on it, and good that both of you are adjusting components of the cooling system to cope with the increased load.
Or, as mentioned by an earlier poster…you could take your foot out of it.
I find conversations like this interesting, and try to resist digging my heels in, but rather adopt a questioning and curious mind, open to new information. Give me something to work with. At the end of the day, it is the knowledge that is important. To that end I have been doing some research to either confirm, or refute my earlier post. It has been an interesting and educational read. In no way can a few hours research by me be construed as by myself “becoming an expert”, so with that in mind…If anyone can add, expand or correct the information presented in a meaningful way, please do.
I hope others find this interesting too.
Your assumption that a clutch fan should work the same as a fixed fan and move the same volume of air is not correct. The clutch fan will not totally lock up; therefore, assuming the same blades on each...it will not move the same rate as a fixed fan. The entire engine thermal management system is designed with this slippage in mind, by people much more learned then I...usually with a pile of letters behind their last name. As a rule, high speed travel brings air through the radiator and engine bay already, and in many instances the fan simply is not needed, where as slow speed…stop and go…high load…hot days…etc can require more air flow and the fan will engage to draw the air through the radiator and engine bay (remember…this is general)
The entire cooling system (pressure system, closed reservoir system, coolant properties, pressure cap, thermostat, radiator, water pump, fan) is designed to maintain as optimum a temperature range as possible for the given engine and “normal” use, over a wide range of operating climates. Adjustments are made for given markets and climates, but the principles are the same. Again, all components of the cooling system, in stock tune, and fully functional are designed to work together. If one component is not functioning correctly then the systems effectiveness is compromised. This may not be noticed till the system is stressed. Also, when you go way past stock trim, or workload the system beyond design, you can exceed the systems designed capabilities.
Too large a cooling capacity can adversely affect engine life and performance. Engine oil, the lifeblood, needs to be at its correct temperature to protect the best (apparently above 190F). The quicker a system can get up to operating temperature, the better it is for the engine. Anything that interferes with this is not good. Thus; closed systems, a thermostat that stays closed allowing a quicker warm up, and some sort of fan system that is designed to create limited air movement when it is not needed…and create more air movement when it is needed.
I wonder if a solid fan, in the middle of winter, would create too much air movement through the engine bay, not allowing an engine to get to “optimum” operating temperature, this increasing engine wear and tear, and aging the oil quicker.
Clutch fans are designed to come on when more air movement is needed, and the closed coolant system can not keep up. When the air passing the clutch fan heats up enough, it does its magic and increases resistance…thus increases air flow. The reverse, as the air passing the clutch fan cools down. The amount of airflow the fane will create, and what is requried are engineered.
The clutch fan is part of the entire cooling system, and therefore needs regular maintenance/checking as well. This is something I have been negligent on, and will be changing.
Don’t misconstrue and assume I am singing praise of the clutch fan, however it has its place and has seemed to work well for many...for many years. It makes sense that fixed, electric and clutch types all have pros and cons, and applications.
Sorry if this seems basic, however it is good primer for me, and lays some foundation for discussion.
crushers said:
I do not think a fixed fan "masks" problems other than the problem of a "auto fan" design that is not working properly
That is too funny Wayne. Maybe it is not working properly because the stock systems ability to manage the thermal load is being exceeded? Again, let me say…if the stock system (read each component in good repair) is working as it should, and the system is overheating…then there is too much load being placed on the system. The load must be reduced…or the system changed to cope with the load. Is there some other way I can word this for understanding?
crushers said:
that clutch fan is not doing it's job which now has me wondering wether or not other overheating problems that occure might not be the fault of the clutch fan not engaging as it should. e.g. towing a trailer with the autos (3F, 12HT). if the clutch fan is doing a marginal job then this might explain why perfectly good 3F auto blew it's tranny pulling a tent trailer through BC on a hot day at normal highway speeds(one case example $6500 repair). that also might explain why the 12HT autos keep loosing their OD due to overheating (personally i have seen 4 cases of this). none of these trucks had shown any signs of off-road usage, no plugged cores stopping the airflow to the fan that should have kept the system cool.
Are you really making the statement that transmission failures are the result of an engineering decision to using functioning clutch fans? I know so very little about the magic inside auto transmissions, however talking about auto transmission failures and blaming them on the clutch fan system seems unreal. Give me your science and educate me...please. If I am wrong, it is an opportunity for me to learn…and I have been wrong many times before
Was the 3F that blew its transmission being driven beyond a stock system in good repairs ability to cool? What was the engine coolant temperature at the time? And what was the ATF temperature? Did the light come on and was missed? Had the transmission ever been overheated in its entire life and not serviced? What was maintenance like? Was the screen blocked? What about those A440’s behind those 12HT’s. Were they driven around the city in 4th, and the lockup placed at that point where it does not know what to do? Again, what is the driving and maintenance history? Are they losing their OD (torque converter lockup) due to this driving style, or is it a transmission lockup pressure fault? I don’t know, and I suggest there is a host of other issues to look at before such a broad and damning statement is made. Go to the 3FE list and search to your hearts content. There is lots of information on the A440, as well as Toyota’s other auto transmissions. Seems the best thing you can do for your auto transmission is add an external cooler like a tru-cooler, and a temperature gauge. It’s like a pyrometer for your diesel, and we all know how much you love singing a pyrometers praise. Drive to the pyrometer and your auto transmission temperature. Rodney’s Extreme Valvebody seems to have done well for Petra’s A440 so far too.
Again, I say:
Recognize if you are going to be on the outer edge of "normal designed parameters from the factory", and make the changes needed to keep the engine thermally efficient...
But don't blame it on the clutch fan...
Get better Wayne. Sick is not fun.
gb
