crushers said:that is what i thought, which is why i questioned the 40k/h.
maybe i was missing something...
crushers said:the problem isn't that the clutch fan quites suddenly, if it did then that would be better than it slowly loosing it ability to cool.
if it actually shuts off at 40 k/h as you say then how does it work on hills at speed when it is needed?
Gold Boy said:Ens Lexus Toyota, Saskatoon.
123.05 Canadian
Heavy duty.
Install on Monday hopefully.
GB
and this is exactly why i do not like or trust these fan systems. when does most over heating occure with a diesel? climbing hills (at least what i have seen around here) or towing. you can rocket all day on the flats with no problems but through in a couple long hills and the coolant temps rise, this is where the fan is needed to help with the cooling. if the fan isn't doing it's job then the problem multiplies at the worst possible time...roscoFJ73 said:I dont think the clutch fan is totally reliant on the spring being heated,its also senses the force of the wind .
crushers said:and this is exactly why i do not like or trust these fan systems. when does most over heating occure with a diesel? climbing hills (at least what i have seen around here) or towing. you can rocket all day on the flats with no problems but through in a couple long hills and the coolant temps rise, this is where the fan is needed to help with the cooling. if the fan isn't doing it's job then the problem multiplies at the worst possible time...
cheers
123.05 Canadian
Heavy duty.
GB
That's what I'm talking about! 3 pole switch all on, all off, or auto. BrilliantEntaran said:I run two electrical fans (and not crap davies craig stuff either). They're jumped off the coolant temp sensor and have a manual override switch (3 position) so I can turn them totally off, totally on, or auto. Took a bit to setup but I never -ever- have heat issues. I've got a brand new radiator too.
Put the hub you removed under the hot water tap and it should expand the bi metal spring this will then cause the pressure on the clutch to increase.I held the heat gun near nine and and check that the spring has not snapped or become disconnected.Gold Boy said:How many hot cfm's through a RAD to engauge the clutch fan.... anyone... ?
Just a silly question, with small possiblilty of an answer.
Thanks
GB
this wouldn't be the same head that you drove home 1000 km from Vancouver with the over heating problem?lowenbrau said:I really liked my clutch fan. It worked flawlessly until it stopped working at all. I drilled a few holes in it and bolted it solid and now it works agian. Unfortunately my head is cracked now. I wonder if it was worth all those extra MPGs.
We might have learned something with this thread though. It seems like blocked rads cause failed fan clutches. Interesting. I hate blocked rads.
