One more note, the starter solenoid requires a ground wire to engage. Perhaps, instead of adding another relay to interrupt power to the starter solenoid, you can interrupt the white with black stripe wire to the starter solenoid through the clutch switch. This way it keeps it simple and less stuff to go wrong.
ground to clutch switch
clutch switch engages ground when clutch is depressed
wire that ground wire to the starter solenoid
that is why I put the switch in.
