BJ60 VS HJ60 frames
canada
Is there any big difference between both ? just want to make sure the one I'm buying is going to be a time saver instead of another task to the work pile .....
thx :)
I believe the engine mounts are different
depends on what year range you need versus what you are buying
steering box bolt pattern changes, along with the transmision crossmember
I could probably salvage that from my actual frame. Should be good to fit the steering box. So since I have the choice Im gonna take the FJ60 frame engine mount should fit the 2h more than the BJ60 one if I understood.
it's been a while since my swap, but I recall the HJ motor mounts had to be cut off the old frame and moved to the FJ60 frame.
legit. the motor mounts have to be relocated and if your from a 6 cyl to a 4 cyl you need the long fan shroud.
