For Sale BJ60 3B Parts, Clutch, Slave, Master, Fork
I will take the intake hose & ac bracket
Could you give the contact number,thanks
Intake hose went with the air box, no ac bracket available.
Dan
Hi Dan,
Would you happen to have the LHS stiffener? (goes bolted to both engine block and T-case)
The part number is 33119-36020 and it is found in BJ70, BJ71, BJ73 and BJ74 and even other trucks carrygin B series engines (complete model list in the link: ToyoDIY.com).
Please let me know, thanks.
Daniel.
I'll take a look, but I don't think so.
I looked and I don't have a stiffener. There is one on the 3BII I sold to @3_puppies, but no extra ones.
Dan
Still have a clutch or two, some 3B injection lines, injectors etc.
Bracket and pump all went together.
Dan
Still have some of this stuff. two clutch masters, one for booster-style master, one non-booster.
$20 each, plus shipping (will fit in medium flat rate box)
Precups/combustion chambers, slightly used, only ran them for a few months, then did a rebuild and installed the new ones that came in the rebuild kit. $40 shipped CONUS (small USPS flatrate)
Clutch Slave Cylinder 31470-60050
$40 shipped CONUS, USPS small flat rate
260 mm/21 spline AISIN clutch and friction disc
$50 plus shipping
Clutch Fork – 1 think this is for 3B/260 mm clutch, bearing sold seperately. SOLD.
Clutch Fork – 2 significantly bigger, probably for 275mm clutch
Side by side
NSK bearing
$35 shipped USPS small flat rate CONUS
Bell housing is available, power steering bracket isn't.
