side question:
Dougal,
on the BJ70 i am also working on, the frame has been galv and then painted over.
are you recommending i sand blast the paint back off and leave just the galv? or will the bare galv inside the frame be enough?
I think that's a common misunderstanding Dougal.
You're thinking as though the whole chassis in immersed in electrolyte. It never will be. Damp or wet patches will always affect only limited areas and for varying durations.
A chassis on a vehicle is not at all like a hull of a ship ... in other words.
Those companies that sell electronic rust prevention systems for motor vehicles take advantage of this common misconception to rip people off.
The electrolytic action is limited to the vicinity of the "damp stone-chip" (or whatever paint damage were talking about).
And the thick zinc coating thats there (from hot-dipping) still represents fabulous protection (at the site of the stone chip) IMO.
We do this all the time on large prefab building. We use Satin coated galvanized steel, then epoxy and polyurethane. <----best system ever.
This was done on the new offices I was working in on the worst location in my country for corrosion and only 100m from the beach. They started rusting through voids/damage in the paint in under 2 years.
These frames were spray-galvanised to start with. If they had been left with the galvanising exposed there would have been some white oxides showing up, but no rust. Instead now 4 years later they have probably had to have touch up work done already.
Bad paint / not enough paint, maybe?.
Don't paint galvanised steel. It can't work as anodic protection if the sacrificial surface is covered with paint.
