Anyone know how much lift the 53-292018 rear coils net on a mostly stock truck, maybe +200lbs in the rear? What about the spring rate? From pics earlier in the thread looks like 2-3"? I am trying to stay around 1 - 1.5" lift.
Greetings. I recently installed this kit that the OP has. I did not have to mess with the KDSS shutter valves for the rear install, but I did loosen them to raise and lower the KDSS piston for the front swaybar to get it lined up with the passenger side control arm. Ride height is spot on all around with perch #5. Alignment came out well, and the truck certainly rides nicer than oem.
Edit for a few misc notes :
- I used a come-along to line up the rear member when reinstalling. I was afraid the lift would offset the rear by too much, but have found my thrust angle to be at 0.02 degrees. Good enough for me.
- fishing an adjustable wrench on top of the new rear bilstein shock to tighten the 21MM bolt without the shaft spinning was interesting and challenging
I put my 6112/5160's to the test yesterday. After the Dove Opener, we went plinking north of Winterhaven, California. Going in and out of our remote, impromptu shooting range, we ran up and down dry washes and dirt roads. With three people onboard and a good 300 pounds of cargo, and 106 degree temperatures, we comfortably saw 60 mph plus on the dirt roads and 40-50 mph in the deep sand and rutted dry washes, caught air one time in one of the washes. The ride was composed and comfortable, the shocks never faded. We then jumped on the freeway and headed back to San Diego with the cruise control set to 80 mph. The 200 Series and the 6112/5160's performed great (much better than I did with the doves).
Thank you. My tires are General Grabber ATX tires 275/70r18 without spacers. I get a little rubbing in reverse at full lock.Truck looks great! What tires/size are you running? Any spacers?
I understand that Bilstein is working on other products for the 200 series, but do not feel comfortable saying more than that.
Love the ride, better than stock for sure (less wobbling) and yes, 1st perch. My understanding is that the rear Bilstein aren't stiffer, just 1.75" lift. I may have gone for it if they were .75"Wow. Sorry about the troubles.
How is the ride with the stock rear springs? When you say the 1" option are you referring to the spring perch? Which perch did you end up at?
Pics of the truck with lift?
I did not think the harsh ride could be coming from such small thing, eventually I found the issue! The driver side rear spring was not fitted correctly, it somehow had popped out and was kinked!! Went back to the shop 2 days ago and quickly fixed It.
Picture of the Spring:
