Progress.
The engine had developed a quiet lifter tick. Since I’d not readjusted the valves after the initial installation of a different cam, I decided the valves should be adjusted. After a couple attempts to adjust the hydraulic valves by first having them a #1 TDC on compression stroke and then adjusting certain valves, and then rotating the crank 360* and then adjusting the remaining 8 valves it wasn’t running right. The tick was gone, but now the vacuum gauge was flickering at idle. I suspected that one (or more) valves wasn’t sealing properly or I’d wiped some lobes off the cam.
I pulled both valve covers and cranked the engine over. All the valves appeared to be opening and closing proper. So it wasn’t a f’ed up cam. So I proceeded to adjust all the valves in firing order… adjusting both intake and exhaust and rotating till TDC of the next compression stroke. After all 8 were done put the covers on and fires her up. It idled super smoothly till it ran out of gas. I didn’t realize that tank was so low.
After pouring some in from a Jerry can I ran over to the gas station. $90 bucks later at $2.15/litre I figured it would be good for a while. It now wouldn’t idle quite right. I tried to make it run right, but it started running like there was bad gas or moisture in the tank:
I drove it around and just when I thought I was through with the bad gas it would run sh!tty again. Pulled the top of the carb and cleaned some shmag and jelly out of the bottom. Still wouldn’t idle right and it surged at a high idle and even when driving with light throttle. It was acting like it was lean… but sometimes smelled rich. I burnt up as much fuel as I dared and decided to pump the tanks dry.
After pumping out the last 10 litres of fuel and putting in 5 of fresh gas, it still wouldn’t idle. The gas was part of the issue, because even at 3600ish rpm the mower would randomly die when burning it. Even with the electric starter I couldn’t get it to start again until I drained some gas out and tried again. The old gas looked crystal clear and didn’t smell terrible it was part of the issue.
So I asked google why an Edelbrock 1406 won’t idle. The answers were somewhat surprising. I found threads describing engines that wouldn’t idle right, fluctuating rpms, stalling at lower rpm, rich smell at “idle”, and restarting after pumping gas. All of which sounded very familiar.
The problem consistently seemed to be the idle circuits. Apparently 1406 Edelbrock carb’s idle circuits easily get clogged. The solution described was to remove the 2 idle mixture screws and spray carb cleaner down the hole with the “straw” or blow compressed air down the hole.
I sprayed cleaner down the first hole and it seemed clear (or to clear out with it). On the second hole the cleaner didn’t flow out but instead backed up and overflowed out the top of the hole. So next I tried compressed air down both holes at higher pressure with the rubber covered nozzle tight to the holes. Air seamed to flow through freely. I confirmed this by spraying some cleaner through both mixture holes. Both now flowed freely,
After setting both mixture screws to 1.5 turns out from bottom, I started the engine. After it warmed up somewhat, I found it ran best at 1 turn out, and it would idle smoothly at 650 rpm. Crisp throttle response, no more surging, and smooth idle. After I drive it some I’ll fine tune the idle… but it seems to be running great again.
