Best way to fix leak in tranny pan?
Discussion in '80-Series Tech' started by Eric_FJ40, Jun 16, 2005.
  1. Eric_FJ40
    Eric_FJ40
    422
    3
    Sep 5, 2003
    It's hot here
    I have had a tranny fluid leak for a while and finally got under there and cleaned everything up last night so I could watch it.
    This morning (Cruiser was not run and did not move) the leak was back and seems to be concentrated at one of the skid plate mounts. I beleive that it is possible that the welds where the tabs hold the captive nuts for the skid plate may be cracked and in turn - cracked the pan...
    Short of removing the pan and having it welded or brazed, what can I do? Will RTV smeared across the area hold it temporarily? Should I grind the paint away and put some JB Weld on it (also good for attaching sliders, I've heard :))
    Any thoughts or should I just suck it up and drop the pan?
    Eric
  2. Tools R Us
    Tools R Us
    23,746
    5,484
    Jul 20, 2004
    Chandler, AZ
    Best way is to drop the pan.
  3. Biff
    Biff
    1,904
    3
    May 19, 2004
    Los Angeles
    use this as a temp fix. Worked for me when I had a leak on my front diff.
    [​IMG]
  4. CharlieS
    CharlieS
    631
    39
    Feb 4, 2005
    One vote for suck it up and drop the pan. It can get expensive when things like that aren't lubricated...
    Charlie
  5. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    you have a skid plate mounted to the transmission pan? :confused:, does not sound very sturdy.
    got a picture?
  6. Eric_FJ40
    Eric_FJ40
    422
    3
    Sep 5, 2003
    It's hot here
    You don't???
    Looks like factory to me - has 4 U-shaped brackets welded to the pan with captive nuts in them. There is a slotted 'skid plate' that attaches to them. I took it off last night when I cleaned everything up - I'll see if I can get a photo of the mounting brackets on the pan...
    Maybe this is another thing that is unique to the 91-92 models?
    Eric
  7. beno
    beno Gihee Arakawa Moderator Supporting Vendor GOLD Star
    25,269
    Media:
    382
    Albums:
    29
    23,196
    Aug 28, 2004
    Woodstock, NY, USA
    Drop the pan...it's easy to do...worst case scenario is that you need to order a new pan. I recently replaced mine and it was a cinch to change. Contact Dan--IIRC $70 or so.
    Here is a thread I posted a while back on this:
    https://forum.ih8mud.com/showthread.php?t=40856
    Best.
    -onur
    Akron, OH
  8. Eric_FJ40
    Eric_FJ40
    422
    3
    Sep 5, 2003
    It's hot here
    Thing is...
    I already dropped the pan when I first got the truck and did all the PM on it. I replaced the screen in there and would like to not have to get in there again (well - I will sooner or later to fix this, but would like to put it off some).
    And yes - I am positive that it is not leaking from me having it off! :)
    Eric
  9. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    nope none on the 96, only skid plates I have are on the fuel tank, under the radiator and the transfer case,
  10. Eric_FJ40
    Eric_FJ40
    422
    3
    Sep 5, 2003
    It's hot here
    Here is the offending leak.
    Best I can think of is that the skid plate took a hit and the force might have broken the weld and compromised the pan.
    Probably would never have happened without the "skid plate"...
