Well you may have seen my other thread about removing/replacing my LSPV. It’s a ball of rust, I been prepping it for a week, steel brushing, spraying with Kroil, tapping, rinse, repeat.
I was able to break the two mounting stud nuts loose, and two of the brake fittings loose, but of course the last one is problematic. I even did the torch and wax candle trick. It rounded off (I was using a line wrench) before I realized it was happening, I wasn’t even using as much force as with the other two fittings that I got loose. Any tips for something else to try?
It looks like I won’t get this off without buggering it up and I may have to cut it. I will have to re-flare the line, it will have to be done on the truck with me underneath there. I have seen some very nice bench flaring units but what kind of flaring tool is best for working on a line under the truck?
Any advice appreciated, thanks, namsag.
