What is everyones opinion on Whynter brand fridges?
Funny thing is, if I didn't have a guage, id never know and just kept driving it - dang guage!![]()
I suppose if you have the little jump start box with you then a single battery isn't too risky. I thought the inverters were additional power losers though, why not just straight 12v power to the rear?
Note: If the ambient temperature is above 32° (90 F) the minimum temperature cannot be achieved...
Besides ARB what other fridges should I consider?
I have had an Engel for six years and it is great! They have fallen behind ARB on the gadgetry, but their fridge is top-notch.Besides ARB what other fridges should I consider?
My ARB has a low voltage sensor (adjustable). It turns itself off before the battery voltage gets too low to start the vehicle. I tested it in my driveway...Left the fridge running for several days. One day, I checked it and saw a warning light and noted the temperature in the fridge was 50* (I set if for 32*). I got in, turned the key and the engine kicked over, no problems! Once started, my fridge turned itself back on and started cooling down again.
Seems like most brands should also have the low voltage cut off...I wouldn't worry about current draw on these fridges (my experience is with ARB only). Seems to draw very little current. Admittedly, I haven't taken any measurements.
How many cranks do you figure you have at the fridge shut off point?
I am not sure about that...it turned over enough to start, but I could tell the battery had been discharged. I probably could have tried cranking my ignition two more times or so...But, GWCruiser seems to have some good input WRT that, I'll defer to him.How many cranks do you figure you have at the fridge shut off point?
I recently read about using a motorcycle battery, installed where the sub goes (rear quarter panel), and a 100w solar panel- for 80 owners wanting a separate battery to run their fridge.
