To each his own, take 'em or leave 'em, but my opinion is that slushboxes and chevy motors alike are good for nothing but boat anchors.
your missing the point, sensitive throttle issue.
That's a lot of manual bashing! Correct me if I am wrong but wouldn't ALL AUTOMATICS be smoother than the manual option? I am very good at driving a stick (as that is all I have even owned) and I would still say that an auto can shift smoother than me?
Don't be so hard on the 5 speeds, remember the rules of simplicity, at the end of the day a manual gives you options an auto never will. And that i will sacrifice many MPG for!
back on topic:
it stands to reason that fewer cylinders means less space to fill with fuel, but at the cost of the additional power.
I'm a firm believer in the benefits of an inline 6 motor, but were I building a rig that I wanted to sip fuel, deliver consistent power, and run at lower revs for hours, I would definitely shell out for a solid 4-banger diesel.
3B H55F
This is not quite true. It is all about how efficient an engine is, I often get similar mileage as friends well cared for TD5 Discovery, his engine is smaller in capacity and cylinders but his engine although more modern has to work harder to pull his car around.
As technology moves ever onwards we will see better use of the fuel that is put in to the engine hence vehicles with newer and better electronic controls are normally easier on consumption however, that advantage can be wiped out in an instant with the failure of a single electronic component. From the moment the tow truck is called to get you to the garage and then the cost of diagnostics (not always correct) and then the cost of the replacement part plus fitting, add in the possiblity of taxi/car hire ect means I will be hanging on to my non electronic 80 for as long as I can!
regards
Dave
All modern tdi engines have similar peak efficiency, like within 5%. From there how they chose to meet emissions targets can make about 20% difference.
From there gearing and driving style is it.
But that's at peak efficiency, which for a diesel is basically 95% load at the rpm for max torque. At lower loads things vary a lot.
The more cylinders you've got, the more internal friction you've got. No if, buts or maybes.
4 cyls win for fuel economy. Which is why all light trucks use big 4 cyls over 6 cyls of the same capacity.
first, the H151 is probably the worst tranny that Toyota introduced into their Land Cruiser line. shifts like ****. O/D is a joke. gear spacing is retarded.
the H55 was a tough, smooth shifting, well geared tranny with a weak 5th gear after 400K. why Toyota took a step backwards is beyond me. and the R series ... wow, now there is a true POS ...
how can you describe a sensitive throttle?
have you driven any other land cruiser engine?
the HDT is not as sensitive as the 13BT or the 12HT, they are a ***** in manual configuration off road or on rough roads. they can be litterally life threatening in certain siturations.
i have found the HDT manual to be uncomfortable in certain driving experiences so like you, each to their own. i won't run one.
if you are happy with yours then that is all that matters in the end.
The more cylinders you've got, the more internal friction you've got and the more surface area for heat loss to the cooling jacket. No if, buts or maybes.
4 cyls win for fuel economy in the engine sizes that interest us. Which is why all light trucks use big 4 cyls over 6 cyls of the same capacity.
LIFE THREATING? I do agree that the ratios of my h151 are a little off BUT IT IS THE BEST manual tranny I have ever towed with! Rarely have to down shift, and 1st is low enough for even a BIG load. There are always pros and cons but at the end of the day I CAN BUMP START my rig in the bush, which is priceless to me in Northern Ontario.
YOU ARE SO RIGHT!!!
Don't get me started on the auto V manual debate, oh alright then.
Auto,
Slower, uses more fuel, engine cannot be pushed started, poor engine braking, cannot change from low to high range 'on the fly', heavier, harder to fault find, often fails with little or no warning, needs additional cooling/pipework, radiator has to be a certain type with cooler (more expensive).......oh I could go on (and often do).
regards
Dave
Should mention that I have just ordered another new car. A Nissan. With manual gearbox.
Oh lord he has seen the light!
regards
Dave
