What are these altered figures you are referring to?
Do you realise that peak engine efficiency (measured in BSFC) hasn't changed more than a few % in decades and that old school mechanical tdi engines are still comparable to the most current common rail versions?
What is different is the emissions levels have dropped hugely, the rpm range is much wider and power for displacement is getting ever higher.
My 25 year old 4 cyl diesel has peak efficiency of around 215 g/kwh. The last 1HD-FTE engines are similar. BMW's 200kw 6 cyl 3 litre tdi hits around 206 g/kwh.
The secondary heaters (usually reverse cycle air-con) is to provide fast heat incold low load conditions. Like being stuck in a traffic jam. That isn't a new phenomenon, very few diesels will reach operating temp at idle in the cold. This is worse when you are running smaller and smaller engines to again minimise internal friction. They don't have the same excess heat as bigger engines with more cylinders.
Any engine can run for a limited time without water.
It is only in relation to old idi engines that people think we have come a long way.
I disagree. The figures you quote are specific fuel consumption figures and, as you hint, make no allowance for the fact that my Audi, for instance and in standard tune, now produces 220hp and 500Nm of torque from only three litres swept volume. This compares with 200hp and 400Nm from the 4.2 1HD-FTE.
The vehicles are not so far apart in weight or size, yet the tuned Audi that I run is now up to around 300hp and 600Nm and hits 100mph up a hill where the LC struggles to hit 70 at the same point, yet the Audi easily manages in excess of 30mpg and driven at an average of 10mph slower the LC seldom exceeds 23mpg-24 if very careful.
Not all the extra efficiency is down to the engine of course but I doubt if aerodynamics has much to do with it during normal driving around here either. Some is down to the Audi having a six speed auto, but most of it must be down to a more efficient engine.
This seems to be confirmed by the very latest design changes to the Audi engine which has lowered the compression ratio and altered the accuracy of the bores when the head is clamped on such that lower pressure piston rings can be fitted to lower overall pumping losses once again. Combined with a new eight speed transmission the combined official economy has now risen from just under 30mpg to in excess of 35mpg on the current version.
Again, I have mentioned that I have ordered a Nissan Juke with a 100hp 1.5 litre diesel engine. It has an official figure of just over 50mpg. There is a new 1.6 diesel out in the bigger and heavier Nissan Qashqai which is more powerful and far more torquey but yet exceeds the little Juke's fuel economy by some 6mpg, both with six speed manual transmissions.
Engines are getting more efficient. I have a lot to do with medium size heavy duty diesels. Tier2 and Tier3 engines have on average an optimum specific fuel consumption at around peak torque, commonly at 1400rpm, of around 210g/kW/h. New interim Tier4 [our european Stage 3b] have fuel consumptions of just over 190g/kW/h, which is around 10% greater fuel efficiency and over a broader working range than Tier2. Yes, they do need Adblue DEF, but this seldom exceeds 5%, so assuming that DEF costs the same per volume as diesel there is a net gain in fuel cost of 5%.
If bought in 1000litre IBC's the cost of DEF can actually be around half that of diesel fuel in the UK.
Audi and Mercedes and BMW are now selling SUV's in the USA fitted with Adblue/DEF systems but they also retain a degree of EGR as well, which my examples above do not. This, I believe, is in order to ensure that one charge of DEF lasts up to 15,000 miles at a far lower infusion rate than commonly used in trucks and tractors which have a DEF tank of just over 10% of the capacity of the main fuel tank on average and need topping up every second fuel stop or so.
