You are correlating an engines efficiency with electronic control and making the assumption that further electronic control will yield further benefits.
Where mechanical tdi engines have no problem matching an
electronic engine for absolute efficiency.
Absolutley correct I am doing exactly that! So, you are saying that if I remove all of the electronics from the latest diesel engine it will make no difference to it's efficiency right?
The gains made in fuel consumption are the following.
1. Direct injection not only giving better thermal efficiency, but an engine strong enough to take lots of boost.
2. Variable geometry turbocharging to provide more boost over a wider operating range.
3. The use of higher pressure turbocharging to deliver more from smaller engines (aka downsizing).
4. Gearboxes strong enough and with enough ratios to get cruising rpm way down. Passenger diesel cars are cruising around 1700rpm now, the current tdi v8 rangerover is cruising at 1400rpm. Courtesy of an 8 speed ZF auto.
So, you are saying modern engines/engineering has benefited in efficency right?
Badly written.
It is about how effiicent an engine is at cruising loads.
Who mentioned cruising loads. where did that come from?
4 cyls and 6 cyls are just as efficient at full load, but at lower loads the 6 has more internal friction, more heat loss and as a result lower efficiency. It's as simple as the internal heat loss and work loss being a bigger proportion of the total.
So, now you are saying 4 and 6 cylinders are just as efficient as each other however, only under certain conditions? So that is a variable right?
It's like trying to feed a family of 4 vs a family of 6. If you can keep all 6 working hard it's no different. But 6 doing the work of four gets expensive.
Good analogy but would it also be fair to say that if the 6 are fitter and stronger (more efficient) than the 4 you get the same work for the same food?
Again badly written.
The engine doesn't "work harder". Such a concept doesn't exist with engines. There is only the torque an engine produces, the conditions it does that under, how efficiently it produces it and how efficiently that power is put to the ground.
So it's false. A td5 does not and cannot work harder than a 1HD-T.
It's either a sick td5 or a badly driven one that drinks like an HD-T. Then again, "often get similar" means very little.
OK, I could have explained that better, try it this way. My friends engine has to consume more fuel to produce the same effort as my 6 cylinder engine making it less efficient?
I must say, you've mastered the art of writing down your nose quite well. I hope you can keep it up a little longer.
At this point Dougal I am going to call it a day with this topic, whilst I was enjoying this discussion and would agree you have some valid points I am afraid your last paragraph was uncalled for. I always thought I could recognise early when dealing with someone who lacks the maturity to have a sensible debate without lowering to comments such as this, clearly I was wrong about that.
regards
Dave
Unsubscribed.
