I found an 80 series with a blown motor for sale (I own a 40 series but never owned an 80). I've been thinking about buying this one and putting a diesel engine in it. Any common or easy swaps you'd recommend?
I have a Detroit 6.5 turbo diesel in mine; Cummins R2.8 crate motor is popular. I'm looking into dropping one of those in mine soon.I found an 80 series with a blown motor for sale (I own a 40 series but never owned an 80). I've been thinking about buying this one and putting a diesel engine in it. Any common or easy swaps you'd recommend?
Do you know who make the adapter for the 6l80 to the om606Om606 or om605. Mate it up to a 6l80 with a manual valve body and go party
Have you actually seen a standalone/full manual 6L80E?? There's lots of full manual options for the 4L80E, but I've found nothing for the 6L80E.Adaptor KIT CHEVY Chevrolet Small and Big Block Auto TRANs to om606
Adaptor KIT for CHEVY Chevrolet Small and Big Block Auto TRANs to OM601/2/3/4/5/6 OM601/2/3/4/5/6 to Chevy/GMC/GM pattern transmissions Fits most Chevrolet bellhousing, small block, big block, LS Powerglide, th350, th400, 4l60, 4l80, 6l80 CNC billet alloy adapter plate and converter bell rated...dieselpumpuk.com
Hehehehe I’m dumb, I meant 4l80 my badHave you actually seen a standalone/full manual 6L80E?? There's lots of full manual options for the 4L80E, but I've found nothing for the 6L80E.
Getawaycarz has their $5k setup and Compushift have been saying coming soon for awhile now, but neither is a simple full manual setup.
I'm keen to know, as here in Auz, 6L80E's are cheap and 4L80E's are stupid money.
Thanks.
I don't have tons of knowledge to share on this, but personally I'd love to have a diesel in mine. I've stayed away from it though since mine is factory triple locked. My assumption has been that if I don't stick with the factory engine then I'm probably using a different ECU, and would most likely lose the ability to use the lockers. Is that true or false? For those that have done engine swaps, have you retained the OEM ECU or used the ECU from the donor engine?
