Best Bolt on Header back exhaust system For 1996 LX450?
Colorado
I am looking to replace the Exhaust system on My 1996 Lx450. 110k Miles. But the rust is taking over. Budget is around 2k. What are the best performance options available? any opinions, thoughts or advice would be greatly appreciated. thanks
PR
EMS powered, most def. :hillbilly:
And if you like that, this fella named Shane has greeeeeeat leather seat kits. :confused:
Edit - just noticed you're new, so it doesn't register w/ you. His stuff was craptastic & worse on customer service. A real gem of a fella.
There are tons of exhaust threads to look through but
Magnaflow y pipe with cat
New denso o2 sensors with oem heat shield
Muffler of choice (loud vs quiet)
Mom n pop joint for routing of choice
Well stated. Having recently read through all those threads again for like the 10th time, IMO you nailed the summary of pertinent points jfz80.
What muffler would you run for a quiet setup? Would you keep the factory resonator?
There's a rumor floating around a stainless madrel bent over the frame exhaust system is in the works by a well regarded MUD vendor. Plan is to bolt up to the Magnaflow Y pipe. Might want to hold off if you want a high quality bolt on system.
I want one. I mean two.
I had planned to have fixtures done for the 80 series this week. I built a prototype for a truck last week. But the last person to build exhaust for that truck removed all of the factory frame hangers. I ended up having to make my own which killed the prospects of building fixtures off of it. As soon as i can get an unmolested 80 in the shop I'll work on getting fixtures built.
^^ Nice looking setup. Love the v bands. Exit looks like it may benefit from being tucked higher with a turn down.
Bigger is better but if you heard my exhaust youd know I havent found the right one ;) Walker makes a quiet or hush series ive heard good things about. My magnaflow is too loud for my preferences. Previous system i asked for flowmaster 80 series and gor 50 series and it was awful.
Keeping a resonator in the mix is a good idea stock or otherwise. I have a vibrant unit on the shelf awaiting install to try and kill my drone.
I used a solo performance muffler that my customer found. It's really quiet. It had a Magnaflow that had a ton of drone with the supercharger. The straight exit was a request. Tucking much higher would make the tail pipe go uphill a bit, i was a bit concerned with trapping consensation.
  • Like
Reactions: RFB
I'd like to see more of that welding bench, exhaust is looking fantastic
yea, Im in.
I like this.
So the op said header back but it does not seem that's what you're talking bout here. That looks sweet anyway though!
Youtube video of the 80's sound? as you know, a good portion of us 80 owners are very concerned with keeping things quiet.
Great looking work!!! Looking forward to seeing how this whole setup develops.
