I finally got back in town and took the LX to a shop to get a handle on the damage. They tried to do an alignment to figure out what is wrong, and came back with pitch and caster values out of spec as follows:
According to the shop owner, it means the rear differential got damaged when the other vehicle hit (the rear passenger wheel) and the entire rear differential ('rear end' so to speak) will have to be replaced. He did go over the underbody with a flashlight and reported that there was no frame damage or any other damage. That said, he didn't remove anything or dig into the rear drivetrain to see specifically what the issue might be as he said the whole diff / rear end simply has to be swapped.
This is quite disappointing, as it is a poor harvest season at our farm so far and he put the damaged at 2800 (USD, ~3800 CAD) at parts for the used replacement rear end/diff and 1500 (USD, ~2000 CAD) for labor, totaling around ~4500 USD.
A few questions for the experts here:
Are rear differentials / rear ends generally replaced whole or is it worth digging into it to see what specifically is damaged? Is rebuilding an option?
Should I get a second opinion? Maybe at the dealers?
What should be the labor cost here that I should aim for as I talk to various shops? Is this a difficult job which needs a very specialist mechanic / Lexus dealer?
Regarding the part cost, I see it selling used online for ~$2100 to $3000 (USA sellers online). What to look for while buying?
Lexus doesn't have a part number for the whole thing as I understand they don't sell it as a complete unit but individual parts. Is this correct? I wanted to see what a new one would cost.
Is it realistic for me to do the work myself? I have done some minor things like changing spark plugs etc. before.
Thank you so much for your help in this difficult time!
I think your splitting hairs, also he in Canada so terminology could be different.If the shop owner told you the “differential” is damaged verbatim, I would 1000% get a 2nd opinion.
The differential is the center piece that bolts into the housing that holds the gears. Even if it was damaged and exploded to bits, it wouldn’t effect alignment
Me might of meant the housing, the housing may be bent.
But if he’s a shop owner and using the wrong simple terminology, I’d get the hell away from them
But it never hurts to get second opinion
Do you guys think it is worth paying someone to take things apart and see what's wrong? It might be a couple hundred more in diagnostics, so maybe I'm better off just swapping the whole differential thing if that is the eventual outcome.
I would absolutely have them double check the panhard rod mount on the frame though. That link probably took the majority of the force from that impact. If the axle side of it is damaged that’ll get replaced. But the frame side will remain, need to insure it is in good shape.
I'm guessing the main tools are a lift and a secondary jack to securely lower and raise the new rear end?It’s actually not a very difficult job if you have the tools.
I think Sequoia and Tundra have 10.5" diffs while LC has 9.5" so that is a no go.
Great point! I should triple check if everything else is indeed in good shape before putting in good money into the repair. On that note, can you think of anything else which should be checked to ensure everything else is in good working order?
__
Lastly, I am seeing prices ranging from 1700 USD for a 2008 with 3.9 ratio & 100k miles vs 2300 USD for a 2015 with 10k miles. Do these generally last a long time and are mostly problem free? Or is it worth paying the premium for a newer one?
