- Thread starter
- #41
No I did not. I do not believe I will be using it. The seal against the fender is tight even without the bolts being tightened or the clips being seated.Did/will you use the 3M tape?
Which often supersed, in vehicles of this age, to whatever colors may still be available.At www.partsouq.com you can put in your vin number. That helps when trying to find color specific parts.
Cheers
Thanks for all of the info. The 4Runner -B5 pad is gray I believe... I like the match. Im working on the same LX flare as you are. Im going to get one.No I did not. I do not believe I will be using it. The seal against the fender is tight even without the bolts being tightened or the clips being seated.
Thanks. Looked it up on www.partsouq.com, contacted Amayama and confirmed they are not supplied to Toyota (by the manufacturer) in beige any longer. Had to find the closest match based on available colors... thus the 4-Runner B5.True but it can help.
Cheers
Adhesion on both sides keeps the moldings tight against the body and also reduces the amount of dirt that gets in between the moulding and the body panels. Toyota did that for a reason. I don't know of an easy way to add that to gaskets that were not made with that provision.
I see value in adding the tape to the other side of the fender pad, but am also concerned about adding difficulty to positioning the flare and/or potential gap created by the adhesive tape. In some ways I wonder why Toyota decided it was necessary for a pre-2000 Land Cruiser but not necessary for 2000+ 4-Runners.QFT / another 1st-hand example - pulled ~15yo 80 flares, no body paint wear.
-Pulled Bushwhacker Tundra flares from truck, were dealership/Rock Warrior part - I have wear into the paint since grit slides behind their single-side gasket.
Dear lord that's a LOT of holes! The project looks great, keep posting up pics!Almost thought I had lost some of the clips until I realized that not all of the possible locations contained clips.
As a matter of fact if you look at the door there are areas where they skipped punching holes for some reason.
If I had not noticed this I may have accidentally glued clips back on into the wrong places.
View attachment 2358012View attachment 2358013
@mtkreitz, do you have any finished photos of your project yet with the 4runner pieces?
