Rich said:All of the diode based isolaters have pretty much the same voltage drop. The solution is to wire the alternator so that it senses the voltage between the battery and the isolater, otherwise, the batteries do not get the intended charging voltage, as you have discovered.
At the cost of greater complexity, go to one of the relay based systems. For simplicity, use a manual dual battery switch.
siglo said:
The ones I have are the Blue top marine batteries (D34M) with only top terminals.. a main terminal and a smaller terminal for accessories etc it seems.Mike S said:I assume from your post that you have the type with both side and top power outputs.
do you think it would be a problem if I run that starting battery and a deep cycle battery together?97 FZJ80 said:Optima makes a reverse terminal Red Top (34R) starting battery that fits the driver's side (LHD) battery tray
mobi-arc said:Quick snap. My photography skills aren't so good.
Scott
Scott
Beowulf said:Two weeks.![]()
-B-
sl33py said:wow - what a surprise, it's been a month and still "COMING SOON!" on their website...
