Battery help 2013 LX 570 (1 Viewer)
Seattle
Battery help needed.
Replaced the battery a few months ago and it’s run fine.
Now it is completely flat, no charge whatsoever. I used a portable battery to jump it but it does 1 crank and dies again. The old battery had the same issue.
Thoughts or suggestions?
I did do a couple creek crossings a couple weekends ago but drove back a couple hours no problem and have driven the car a few times since then so not sure if it’s the alternator which was replaced 3yrs/35k miles ago at 87k miles.
Thanks!
Yes. And pull the door sill trim to check for water.
Sounds like an alternator to me. Was your replacement OEM? Denso? Other?
You could re-charge the battery and start testing fuses for parasitic load...It's possible you've got a drain on-board somewhere.
What is the normal alternator voltage at idle?
I have 13.4
The answer is: It depends on state of charge, temperature etc. These alternators don't have a fixed voltage regulator.
