Battery help 2013 LX 570
Seattle
Battery help needed.
Replaced the battery a few months ago and it’s run fine.
Now it is completely flat, no charge whatsoever. I used a portable battery to jump it but it does 1 crank and dies again. The old battery had the same issue.
Thoughts or suggestions?
I did do a couple creek crossings a couple weekends ago but drove back a couple hours no problem and have driven the car a few times since then so not sure if it’s the alternator which was replaced 3yrs/35k miles ago at 87k miles.
Thanks!
Yes. And pull the door sill trim to check for water.
If all else checks out, look for a parasitic drain on the battery. Lots of YouTubes that show you how.
Sounds like an alternator to me. Was your replacement OEM? Denso? Other?
You could re-charge the battery and start testing fuses for parasitic load...It's possible you've got a drain on-board somewhere.
What is the normal alternator voltage at idle?
I have 13.4
The answer is: It depends on state of charge, temperature etc. These alternators don't have a fixed voltage regulator.
