- Joined
- Jan 29, 2012
- Threads
- 0
- Messages
- 4
Can you give some more detail about water tank? Curious what brand and size? Suggestions?
It looks like my new LP cylinders fell off the truck a few times on their way to me. Both tanks' safety collars and foot rings are bent. It turns out amazon doesn't allow these to be returned, so they are sending out a replacement pair & told me to dispose of these as I see fit. Has anyone made an OBA tank out of an old LP tank?
Body
REZARF's method of body construction (thin tubes and sheetmetal) works for me, so I "borrowed" it.
I layed out my plan on graph paper first and then re-did it at 1:1 scale on poster board. Then it was a matter of cutting the tubes and piecing it together.
the sides are 16ga that I had bent at a local steel vendor. The floor is 14ga.
There are five body mounts welded inboard of and flush with the top of the frames. The tub itself just has holes drilled through the floor to line up with the lower mounts. There is a .5" piece of delrin between the tub and the frame.JamesR said:Great write up and your fab skills are amazing. I have a question about the floor. Did you drill holes on the edges to weld to the frame or did you weld the sides to the frame?
larcie said:Those leaf springs are looking VERY flat!
Too flat!
