Hey Y'alls,
I have a rig throwing code 0420 (1996 FZJ80) and according to the FSM that means the cat is not working properly. So....how do I know it's not one or two bad oxygen sensors? My mechanic (LC specialist) tells me we should replace the cat. But that's $350 (he says) to install the Magnaflow cat, which by all accounts is not as high quality as the OEM cat, and I still don't understand how you can know for sure it's the cat. Also, there are two cats. How is a person to know which is bad based on the code?
I did test the O2 sensors per the FSM and each tested fine, but that test is not visual only electronic and it seems the sensor could pass the test and still be faulty. Is that right?
Thanks for any help you can offer,
Russell
Russell
