Back in the Game - Added an 2005 GX470 - Toledo Ohio (3 Viewers)
Hornd
Toledo, OH
Truck will be based line to make it as Reliable as Possible.
Truck from Columbus Ohio, I'm 3rd Owner, 200K and Most Maintenance Records.
Has 2023 4 Runner Rims & Tires as Owner wanted to keep Aftermarket Rims
Issues - Solutions
Run VIN# to get Lexus Service History - Done
No Mud Sticker - Add Mud Sticker on Rear End - Done
KDSS Oild Needs Changed - Thinking Aftermarket Fluid Since OEM is $75 - No KDSSS Per Lexus Build Sheet
Tranny Fluid Likely Never Changed - Drain, Measure, Replace with Aisin ATF WS - Change by Dilution to Protect Torque Converter - Drained & Replaced 10 Qts - Done
Replace Broken Wheel Stud - Dorman Part - Done
Rear Airbags Leaking - Already Replaced with MOOG Coils (Part # 81045) and Airlift Bags (Part #60809) and MOOG Spring Isolators (Part #160061) for Top of Springs. Plumb Air Bags to Schrader Valve. - Done
Suspension Compressor Toast - Remove and Maybe Replace ($150 Ebay)? Plumb Air Lift Bags to Shrader Valve and Mount Valve. -
Replace Cabin and Engine Air Filters with Densos from RockAuto.com (Buy 2 of each, apply 5% Discount Code) - Done
Spare Tire Trashed - Corrosion - Sand Blast & Repaint with VHT - Get used Tire for Replacement - Went another Route. Bought New Tire Ebay ($105 and Used Tire Ebay ($45). All Tires and Wheels Match. Sell Original Spare??
Replaced Center Diff and Rear Diff Oil - Done
Rust under Passenger Brake Light - Remove Housing, Wire Wheel, Naval Jelly, Brake Parts Cleaner then Prime & Paint - Done
Remove Rear Hitch Plate - Weld and Bolt on Hitch Step from Ebay - $40 - Bolts Snapped off - Drill & Easy Out - Bought Drawtite Hitch Amazon $200 - Need to Relocate Light Harness
Replace Incandescent Interior & Runner Board Lights with LEDs - Done
Install SAIS Bypass -
Rusty Chassis - Wire Brush, Compressed Air, 2 Gallons Fluid Film - Done
Remove Sagging Rear Door Cargo Net and Replace with Folding Table from Ebay - Done
Clean Fuel Door, Door Sills and Hatch - Simple Green & Toothbrush - Done
Check Condition of Wipers Front & Rear - Order 2 Sets Denso Rock Auto (Buy 2 of each, apply 5% Discount Code) - Done
Order 10 Qty Case of Oil Filters - YZ-D3 - Already have from 80 Series
Leather Treatment - Apply Lexol or Griots Garage
Protect Cargo Carpet - Order cut to Fit Rubber Cargo Mat from Amazon and cut to Fit - Thinking DIY Drawer Setup.
Wire Wheel and Paint Exhaust Rust with VHT Silver Very High Temp Ceramic - Done
Check and Replace Missing Bulbs in Interior Switches - Ordered - Arriving 3-28-23
Replace Squealing Idler Pulley - Replace with Nachi bearing - Ordered SKF RockAuto $36 - See Post Below - Done
Order Tools for Timing Belt Replacement - Crank Tool, Caps to stop Leaks, etc
Replace Power Steering Fluid with New Full Synthetic ATF- Ordered - Done
Purchase Front Brake Backer Plates - Ebay $80 for LH & RH
Replace Backup Lights with LEDs - Amazon 4770 Bulb after Removing Rear Door Panel - Done
Replace Fog Lights with LEDs from Ebay - Ordered -
Failed Bulbs too Tall
Polish Out Headlights with 3M Kit in Drill - Ordered Ebay - Done
Remove Wheel Speed Sensors (433mhz and Replace with Denso 333mhz) and Program with TechStream - Ordered Sensors Rock Auto - Use Highlift Jack Under Hitch to Break Tire Bead and Install Senor
Rusted Power Steering Line - See if Available Aftermarket - Available for $100 - Replace when doing Timing Belt
Exhaust Pipe Cracked at Flange Behind Muffler - Manaflow?? or Sleeve with Stainless?
Parking Brake Lever Not Ratcheting - Remove & Clean -
Sagging Covers Under Seat - https://www.youtube.com/watch?v=fxM3SB2swlY
Nice. I am from Ohio too.
The jeep tailgate table for $40-50 fits pretty nice too. It cover the area where the saggy net is almost perfectly.
👋🏼 C-Bus, Clvlnd, or Cincy?
You talking the Table on EBay? Linky?
Before
Before - Went over it with Wire Wheel in Drill.
For a Spare it will be out of Sight 99% of Time.
Now headed to Marketplace/Craigslist to find a decent used Tire.
Tranny Fluid Ordered for Exchange
Old Bearing was making Noise
NSK From RockAuto is same as OEM - Arrived in 3 days
Hobo Freight make a Double Ended Long Ratchet with 3/8" Ratchet on 1 end and 1/4" Ratchet on other end. Makes Turning Tensioner 14mm Bolt Head Super easy.
5 Minute Install.
Old Hood Gas Struts No Longer Holding Hood Up - Leaking
New Struts Ordered from Ebay - $17
M12 Open End Wrench to Remove - 5 Minute Job - Use Piece of Wood to Support Hood
These will not Fit - Too Tall. Wasted $10
Fog Lights - Halogen --> LED from Ebay - $10
LEDs too Tall - Could not Use.
Way to bring it back! Certainly was pretty crusty!
You will find those fog light bulbs probably have near-zero output (likely due to the ol LED in halogen fixture issue) I changed out my golf cart lights with some of them and the amber running lights are brighter than they are lol.
I'll do some Before and Afters.
I will show the Wins & Losses - No Shame in my Game.
Rear Fuel Tank Strap Rusted Through.
Powder Coated new Straps from Ebay.
Wire Wheeled Pins and Coated with Ceramic VHT after Heating them with Torch.
Tank is Plastic & Shield is Steel.
Shield is Prone to Rust on Inside.
Black Dots on Paint - Appears to be Mold.
Wiped with Degreaser and Coarse ScotchBrite - Rinsed with Hose
Then Waxed
This White Pearl is Beautiful Paint with Lots of Sparkle.
Out with the Old
Both Rotors were Trashed on Inside Surface.
Drivers Side Emergency Brake Shoe Pulled off With Rotor.
Installed New Bilsteins While in there.
Cut off Old Shocks with Sawzall for Top Stud and 17mm Socket for Bottom.
Pretty Easy Retrofit.
RockAuto.com has best prices, Cheapest Shipping and Parts Arrive Fast.
Always Google and Apply the 5% off Coupon which helps Cover Tax.
E-Brake Shoes and Hardware Kit on way.
Headlight Polish Bilstein Brakes Rotors Pads Shoes LED Headlights
Polished out the Headlights
I cannot Recommend the 3M Kit Enough
Takes 30 mins per Headlight and the Results are Outstanding.
Chuck the Velcro Pad in a Drill and Spray with Lots of Water while working thru the Grits.
Finally Wipe 2X with the Clear Coat & Remove Tape.
Added some $30 LEDs from Ebay.
Prefer the LEDs with Fanless Drivers, as Reliablity is Assumed to be Better.
*I've had some Ebay LEDs last a very Long TIme and other Last a very Short time.
**Upgraded ($45) to the LED Headlights from Superbightleds.com and they lasted the same as the Ebay ones. Some very Long others Short lived.
Write the Install Date with Sharpie so I know how long the Item Last - Especially on Cabin and Engine Filters.
Replaced the License Bulbs with LED Panels.
LEDS are from 4 Runner so I put a Single Hole and Screw to Secure them.
No Comparison in output, voltage draw, or durability.
Once and Done for Life of Vehicle.
LED Pair is about $15 on Ebay or Amazon.
Ordered a Set for the 80 Series
  • Back
