- Thread starter
- #121
Glad to have the privilege to know you now and have had your expertise on this truck! You are seriously awesomeWelcome to the community J. Your 80's previous life was rough. You should be good to go for many more miles now.
Here's more of a break down of what was causing it to pull right.
The bearings, TRE's and knuckles were worn for a typical 265k mile 80 but wasn't causing the issue in question.
The right rear lower control arm was bent enough to make the right side 1/4" shorter both bushings were mush from extended neglect.
The call was made to replace the rear lower control arms with Dobinson adjustable ones. Excellent quality and a direct replacement.
