Avid rear bumper and swing arms look good
Poway, CA
Over the weekend I installed an Avid rear bumper with dual swing arms. 80% of the effort involved removing the original pieces, cutting 3.5” off the end of the frame, and cleaning up the old weld lines. Once that was complete the installation went very smoothly. I don’t have a lot of experience with such parts, but I am an aerospace engineer, and this was a quality piece of work.
Only one mild gripe … they did not include new mounting fasteners. The old ones kind of work but they really should have bigger heads and beefier washers. I found a great selection of such stuff at Belmetric and will swap them into the vehicle when they arrive.
I've been running this bumper on my 80 for 2-3 years. Its taken a beating and held up pretty well. I was frustrated when I got it because the 2" receiver was too small to receive anything. I've got a super heavy 37" spare mounted on it and I hopeful it will hold up. Havent tested it on a full blown trip yet.
3eaa1314-fba6-4cdd-932d-8d36dcda90f6-jpeg.3221306
No turning back when the angle grinder comes out... :clap:
The bumper looks good.
Too bad to hear about the 2" receiver hitch issue.
Your post got me very worried so I just tested various items. A standard Reese and a standard Haul Master both fit fine. Another off-brand fit OK but was snug. Would probably wire brush and lubricate it. Then I tried a Harbor Freight luggage carrier and it did not fit at all. The corners were basically square without any relief. So it appears to me that most units will work but a few may need attention on the corners.
Yea I ended up with an extension that I grinded the corners off of and used a small sledge to force in there. I only use mine for a bike rack.
Nearly a year. I like the folks at Avid very much, but they are a small business with a great product, and their supply chain simply failed. They estimated 3 months in February 2022 and slipped 3 months at a time after that. About 6 months after I placed my order they took their ’80 rear bumper off their web site - they just could not get the parts fast enough to make a sales commitment. Good for them for that. I hope the supply chain stuff settles out and lets them run a more normal business again.
How much does it weigh?
Not sure exactly. I think that FedEx had the pallet at 180lbs. I would guess the bumper with the swing arms is 120 to 150 lbs. Enough that it feels heavy when two decent sized guys lifted it into place. The mounting fixtures for the spare tire and the Jerry cans are probably 20 lbs each. The sheet metal is 3/16”.
I've been waiting for over a year now and it's starting to get frustrating. I was originally told 4-5 months, last May.
What were the bolt patterns that you ordered from Belmetric?
I ordered hardened, flanged bolts. I think they were 13mm? My memory is that I replaced only the larger bolts and used the smaller ones (8mm?) from the kit. The mounting holes in the bumper are somewhat oversize to accommodate variations in the hole locations and help get everything aligned. I thought the flanged bolts were a good call to avoid pulling the washers into the holes. I saw deformed washers when I took out the previous tow hitch.
Sorry to hear about your wait but not surprised. But FWIW, I was very pleased with the quality of the unit.
I waited a year and two months. Received it last month. It's a very well built bumper and but if I could to do it again, I'd probably just get the coastal offoad bumper and weld it myself.
