Whatever Toyota Matt sent me I have for temp gauge. I bough the cluster pod from him as well tooDid you use the stock sensors or install separate sensors so the stock gauges would work also?
@ToyotaMattWhatever Toyota Matt sent me I have for temp gauge. I bough the cluster pod from him as well too
I replaced the factory dummy gauge with the mechanical one in the same hole. Gives actual readings including after you turn off the truck and you can see it rise
forum.ih8mud.com
I ran my 60 with a sniper across the country in the spring time last year. Went from Florida to Montana completely loaded down. I’m running a 190 T stat.This is a very informative thread. Lots of great input.
I’ve got a scenario for the brain trust.
Dyno tuned Mosley 2F. Runs perfect. New OEM red fan clutch, water pump etc…all stock
I have about 250 miles on the break in.
Sniper and OEM temp gauges. OEM is in head. Sniper is in rear if the engine at block drain where I put all of them on my Snipers (20 plus)
Ambient temperatures during all 250 miles have been in the 90s
This truck runs about 215 versus my 60 that is set up just like it that runs around 200 in Same conditions.
Today I pushed it hard and it briefly hit 220. As soon as I slowed down and went to stop and go it dropped to 215 or so.
Got home. Popped the hood. Overflow bottle was full but none had flowed out.
This is across from input hose
This is at the cap
This is shooting the OEM sensor
This is the gauge
This is the Sniper after it sat at idle for about 10 minutes
Cam thinks it’s a 190 thermostat.
What bothers me is that 220. This is all with AC on Blast.
What’s a 190 t stat? I thought there was One t stat@wngrog I may be wrong about this but I seem to recall reading that the 190 T-stat begins to open at 190 and is fully open at 220. Or there about… I have no idea where or who posted that, so take it with a grain of salt. But, makes sense if you never peaked past 220.
Started the cruiser last night, I have small Pressure in the cooling system which is causing the coolant to boil EARLY, which my mechanic buddy thinks is causing my overheating problems. I’m a side note….What’s a 190 t stat? I thought there was One t stat
My cruiser spit fire from the exhaust on multiple occasions (no cat) and am wondering why this is happening. Might lean it and advance it a little!
Thanks
Dan
stock radiator. do you mean IR temps?what’s the radiator?
Timing is "hot"?Timing is hot I’d bet. Burp your system more if it’s getting hot too fast.
I installed one from @ToyotaMatt that opens up at a lower temperature.Timing is too advanced and too much fuel going into intake manifold.
There are two different T-stats available and they open at different temperatures.
You might also benefit from doing a valve lash check / adjustment.
This is at the cap
This is the gauge
Like 1100, I can get it down to about 850 but it starts sounding like s***. I literally have timing set to -1 from BTDC according to the timing light, so how could it be off still? If it was a tooth off I thought it wouldnt be able able to get the timing light to flash the BB at this point, or am I mistaken?@Beehanger
What is the RPM at idle speed- if you are able to raise front of truck to help burp it- do this until the temp gauge reaches normal operating point, have the radiator cap off, then shut off engine. Coolant level should drop in filler neck as air is purged out of engine.
If your idle is above 850 then I think you may be right about the dizzy being off. Vexing process !
