FJBen
As long as they don't shorten/lengthen the EGT cable as that messes with the readings.
Sent to them.As long as they don't shorten/lengthen the EGT cable as that messes with the readings.
If you're working on an HDJ81 make sure to check the two wiring harness connectors under the windshield washer reservoir, it seems that spilled washer fluid over the years corrodes the wires and causes all sorts of problems.So got my 80 back finally. Happy with the performance. But I have a feeling the auber install fried my stereo and dome lights. They plugged into the #1 slot for cig light, dome and radio etc. They used an adapter to house to 15amp fuses for auber and the former items. I pulled adapter and plugged single 15amp fuse back in and no radio or dome light working.
Stereo runs under dash panel. #1 slot. Cig lighter, etc.You're checking the fuse under the hood in the small panel? I had some issues with a funky stereo install that caused the same issue and tossed the 10A under the hood.
Ok thanks. I'll have a look at that.If you're working on an HDJ81 make sure to check the two wiring harness connectors under the windshield washer reservoir, it seems that spilled washer fluid over the years corrodes the wires and causes all sorts of problems.
Yup. Mine popped the fuse under the hood, but not the one in the dash. My truck is a 1992 HDJ81. I was installing a stereo and there was an issue with the harness.Stereo runs under dash panel. #1 slot. Cig lighter, etc.
Ok great..ill check that. Do you know which fuse it is?Yup. Mine popped the fuse under the hood, but not the one in the dash. My truck is a 1992 HDJ81. I was installing a stereo and there was an issue with the harness.
I lost my dome lights, cig lighter, and radio, and they came right back on when I replaced the 10A fuse under the hood in the small panel.
Awesome thx! That should do it. I'll let you know in a week If that's it. Van island for a week holiday.I went out and checked. I have a small aux fuse panel under the hood on the LH side of my truck, behind the battery.
When I'm standing against the fender, the fuse in the bottom R corner is a 10A, and is marked as "Dome" on the cover.
That's the one I popped that cut off my head unit, and dome lights, and cig lighter.
Hopefully that helps!
So just got home and checked dome fuse. It was blown. Now I'll have to buy a few 10 amp fuses and troubleshoot. I still think the auber is probably the cause.Awesome thx! That should do it. I'll let you know in a week If that's it. Van island for a week holiday.
Replaced fuse. So far all good. Nothing blew.You may be correct, but at least you're barking up the right tree now!
Good luck!
