STILL AVAILABLE!
Selling my beloved beast
2000 Lexus LX470
191XXX miles and climbing slowly
SOUTHERN Atlanta, GA vehicle it's entire life
Timing done (& water pump etc) at 92K and 180K
Garage kept at home and at work
Completely stock, never off-roaded or mudded.
It appears that I am third owner. It was a "Corporate" car, and then the PO bought it. Hence, I am third owner. Purchased from elderly gentleman who was also in Atlanta, then moved to a Vacation home 1 hour north of Atlanta, then was moving into an assisted living facility and needed to sell. Garage kept at both of his homes.
I bought it in June 2015. It had around 166K on it.
Used as a daily driver, but my commute was 7 miles.
No check engine lights, no noises, very smooth engine and transmission. AHC goes up and down.
Sunroof works. Rear side vents work. Antenna works. Heated seats work. Cruise control works. Cold AC, hot air, rear vent works. 3rd Row seats available.
Used and loved well. I have a kid and 2 dogs. This 100 is well kept, but it IS a used SUV from the year 2000, and I expect a buyer to be very aware of this.
I will be happy to answer any questions to the best of my knowledge.
**Carfax is showing a 'minor accident' involving rear impact. "Usually cosmetic including dents or scratches". I am working with Carfax to rectify.
Asking $8900!
Here is a list of what I can remember doing to it. There might be a few more things here and there:
2017
Front/rear pads and rotors
Mass air flow sensor
Spark plugs
3 or 4 coils
Transmission drain & fill w new gasket
Valve cover gasket
Manifold gasket
02 sensors
2018
Timing belt
Water pump
Pulleys
Heater T's
2019
New Battery
Rack and pinion (used OEM, 95K mile donor)
Lower control arms (used OEM, 95K mile donor)
Repacked hubs
Grease shaft
Professionally refinished front seats and arm rest by guy who does Ferrari Dealership upholstery in North Carolina
"Clock spring" steering angle sensor
Alignment at Toyota Dealership on 6/13/19
2000 Lexus LX470
Asking $8900!
2017
Spark plugs
3 or 4 coils
Valve cover gasket
Manifold gasket
02 sensors
2018
Timing belt
Water pump
Pulleys
Heater T's
2019
New Battery
Repacked hubs
Grease shaft
