- Joined
- Feb 8, 2004
- Threads
- 294
- Messages
- 5,760
- Location
- Cloverdale B.C. Canada
- Website
- www.instagram.com
mine is like 12.5-13 inches from that shock mount rib .almost inline with the rivet on the frame .
Normal Chevota radiator location would be rearward and downward. Rearward because the rad will be too far in front of the fan blade. Downward because the fan blade center will be well below the rad center, and even possibly cutting through the path of the lower rad hose. Typically bottom of rad mounting housing would be close to bottom of front crossmember rather than on top of it. Engine position wise, guys use to cram the engine back into the firewall trying to save drive shaft modifying bucks (they merely swapped front to rear), but then there was no air behind the engine and those rigs ran 240 degrees all day long. Heat radiated out of the back of the engine, hit the firewall, then bounced right back into the engine. Many problems with the engine too far forward, I won't even go into that.
Might have some parts you need as I just pulled a V283 from my 67'Fj40. The engine was shot, but had a new clutch kit, new NOS SM420, and 3spd transfer engine had an avenger carb/truck, not sure what adapter was used, but the engine was fit nicely in the engine bay. I am putting an F2 engine in the truck with a split case, so everything is available - drive shafts, rear cross member. It all in Connecticut.
I would redo it. You have pretty much everything you need already. I went back as far as I could go due to having it mated to a sm420 so I could get it past the heater. I installed it about 1" towards the passenger side to allow for steering clearance. The slope of the set up should be about 3º from front to back to a max of 5º. I also put it as low as I could for good COG. I have the motor out at this time but can snap some pics if you want.
I think when they did the swap they got the driveshafts backward and they just moded the truck around the driveshafts. The difference in driveshaft length would suggest this
In my truck? I would certainly hope they couldn't be that dumb...but given the other "mods" I've dealt with so far, anything is possible...My front driveshaft is significantly shorter than the rear, obviously a result of the engine being tucked way up front. That said, I don't think moving the engine back would allow me to simply "swap" the driveshafts, they'd both need modifying. I'll try to remember to take measurements next time I'm under the truck.
When it comes to stupidity I never underestimate the human race. These mods look to me like one of those shops that Jim c talks about in his thread "how not to restore a 40". I'm sure the driveshafts are assbackward and all it takes is a simple measurement to tell
I too have a 77/40 all original with 57k on the clock and I just measured the drive shafts
Front is 29 1/4"
Rear is 21 1/2
With a difference of 8 1/4. Looking at the pictures this seems to explain it to me at least
Now the driveshafts do have a slide yoke and that makes the mesurement +\- about an inch and mine are installed and no lift
With all the effort you'd be expending to correct these issues, do you think installing a stock drivetrain would be an easier/cheaper alternative at this point?
The funny thing is, this truck was apparently converted by an actual shop that specialized in this - "Go-Ten" manufacturing, in Union City, CA. I have a sticker on the door frame. The sticker also indicates a 1971 350SBC - the engine that is in there is definitely a 1965-67 era 283 SBC. Obviously the engine was changed, but I'd be surprised whoever swapped the engine went through all the trouble to move the mounts...doesn't make sense to me...
My driveshafts are currently out of the truck due to my axle overhaul - I'll try to remember to take some measurements tonight and report back. Either way, it sounds like the "right thing to do" is to move this engine backward 3-4 inches. This poor bastard has been through enough hack jobs in its life, I'm just trying to be a GOOD PO
That said, it does get very old spending asinine amounts of money to fix someone else's stupid...
if you move the engine back, you will not need a fj60 cover thingy. you will need to get the original shift mechanisms tho. the exhaust is easy with the walker cross over pipe.
That should have you covered. Should be able to just shorten the exhaust somewhere pretty easily. You may want a new shifter for your transmission.
