Are all keys the same? (1 Viewer)
North Bend, WA
I have a 1976 fj40 project that does not have a key. If I pull a cylinder to get the code to have a key made, will that key operate all the locks?
if all your locks have the same factory key code , then yes .... :)
if all your locks have different factory key codes , mis-matched for all sorts of various reasons ?
then
NO ,.... :confused:
- the only way to fond out is pull put your passenger side front door lock and examine it carefully for the K- SERIES four digit code ......
- then , request a factory SST machine cut . digital computerized perfect , sharp , true , and professionally code cut K-SERIES 1976 master all metal top basic OEM key blank ,
lube up all lock with WD-40 days , like many days before trying new oem code cut key ,.,
follow these above TOYOTA OEM Factory step by steps , then you shall have a correct final answer for all 4 of your doors locks / ignition / flip down fuel door ....
if you have a bunch of random locks and only or no matches ?
then there is yet still hope for you below .......:)
THIS IN THE WAY.....
