Anyone use Safety Wire on their trucks? (2 Viewers)
NLXTACY
Wits' End
Medford, OR
I had a knuckle bolt that was loose after my last snow run. I was also reading up about one of the 60s guys having both of his caliper bolts lost while in Death Valley.
Safety Wire is something that I used on my 68 Camaro back in the day but I actually never gave serious consideration to using it on my Landcruisers. I wanted to see if anyone else has, considered it, or thinks its a lame idea because we are all bad ass with PM and no way our nuts would come loose. :rolleyes:
Tips:
Safety Wiring - More Than You'll Ever Need to Know
Parts:
Wire supplier of stainless steel wire-lock wire and safety wire-aluminum wire-brass wire-copper wire-medical wire-fishing wire-fishing leaders
Jig:
http://www.pegasusautoracing.com/productdetails.asp?RecID=1192
I have an continue to use safety wire on some items. I haven't had any issues with the knuckle nuts or studs as you have. Drilling the knuckle studs to accommodate safety wire provisions might not be the best idea because you will reduce the strength of the stud. Remove the nuts and thoroughly clean the nuts & studs and reassemble with thread locker.
Search a little more because those drill blocks can be had in the $50 range.
Lockhart Phillips Metric Bolt Drill Jig :: Hardware, Jigs, Safety Wire, etc. :: Solo Moto Parts
Lockhart Phillips Nut Drill Jig :: Hardware, Jigs, Safety Wire, etc. :: Solo Moto Parts
Machined Nutplate Bucking Bars! (orange block)
SAFETY WIRE BLOCKS / DRILL JIGS - ENGLISH OR METRIC
POSSE SAFETY WIRE METRIC BOLT DRILL JIG
Safety wire has it’s place, it’s great in relatively soft connections, where there is some flex in the connection, like valve covers, etc. In highly stressed connections, like your talking about it’s not as helpful and can be worse, cause more damage than using nothing.
Highly stressed bolted connections should be assembled metal to metal, with no debris, paint, rust, dirt, etc, then tightened to the proper torque. The most common failures are improper torque (over or under) and debris, these can and do happen without the fastener turning. The most common debris is paint, it looks nice to put a couple of thick coats of paint on everything, but if between connections it makes a nice bearing surface. This allows the connection to move, if it moves once, it will move more with the next big load, repeat, as it moves the debris is spit out causing further loosing until it fails, in the early stages the fastener doesn't turn.
Early on we ran safety wire on our off-road race car and found the failures to be more disabling/expensive. Without a “locking device” fasteners come loose, you hear/feel it, most of the time it can be somewhat tightened/reassembled enough to get you off of the trail, home. When safety wire was used , the fasteners are still loose enough to move, but you may/probably wont feel/hear it, the failures were more complete, instantaneous. The connection moves, hammers until the fasteners fail, usually all at once, causing a more catastrophic failure.
Have done thousands of brake jobs and overseen many more at the shops where I have worked and have never seen a properly mounted caliper come off. Tighten the fasteners “about that tight” and/or install that freshly painted caliper on that freshly painted knuckle without removing the paint from the mating surfaces and your just asking for it.
On the knuckle studs, as these rigs get bigger tires, wheeled harder we may start over stressing the studs and need to beg someone to make stronger ones like are available for the earlier rigs. The right side on mine came loose after the first aggressive trail with the 37’s, cleaned them up and torque to spec, have retorqued them several times and they haven’t moved.
Locking devices have their place, but IMHO highly stressed bolted connections (suspension, knuckles, brakes, etc) isn’t the place. Periodic torque checks allows for much better monitoring of fastener/connection health. None of them should move when torque checked, if you have a fastener that moves each time, it has probably suffered plastic deformation (stretched, over torque/overload) and needs to be replaced.
Yeah, we used it on the HJ45 to replace Toyota's safety wire on the Throttle linkage. We were adjusting the idle.
It's so easy a Six Year Old can do it.
