- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,205
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Nay said:I'm just a contrarian here. I think the limited flex and rigidity of the 80's front end is a strength, because it is such a heavy vehicle with a long wheelbase. The fact that the front end doesn't compress back and push down with an overly flexy front end allows this tank to climb a lot better than it should for its size and weight.
I really thought I would redesign the front end, but with use I have come to value it. The rigidity controls 35's nicely onroad and the stock arms are pretty much indestructible sliders offroad that still climb well. Given it can already handle any trail that I would take a rig this big on, the only real issue is caster. Cut and turn is the best solution.
Nay
If your happy with the stock performance, then there is no need to change it.
Cut and turn is less than ideal on the 80, the tie rod is between the radius arms and pinion. If the knuckles are rotated to correct caster the tie rod hits the arms, requiring new radius arms and/or steering arms.
