The trailing arms we build are about the most complicated item on the trailer. They are build using a template that's completely aligned so everything is parallel, but we still have a 20% reject rate due to warping during welding.
Apart from the welds producing a warp the stub axles have to be welded in with a butt weld and there is some wiggle room between the shaft and the tube it's being welded into. So you can have a perfectly square arm with a spindle that's off.
Since this Spring we have introduced an patented adjustable trailing arm allowing for alignment in the camber and toe in. The difference in performance both on and off road is much more apparent than we had thought.
That is why you guys are #1!
Good stuff here Martyn, what do you do with the 20% rejects? Gotta a garage sale anytime soon?![]()
Also I have thought heavily about building an imitation independent rear arm suspension similar to AT's. Martyn have even been supportive of it which is awesome. I have been thinking about building a custom trailer for a long time. But after intense discussion with Kurt Williams, whose trailer uses a regular old straight axle and (**key being**) long leaf springs from an auto application (FJ55 rear leafs) and it hauls ass at 75 mpg on the dirt roads and 90mph on the roads just fine. Bery little liability, Kurt also drives like a madman sometimesI think this actually be my route though it is slightly "less cool"
Timely discussion Andre... My Trail Trailer vers.2 will have a totally different suspension underneath it... simple, yet adjustableI'm keeping quiet about it until I pull it off... stop by and I'll show you the parts. The only reason I am interested in changing suspension types is to acheive a lower profile trailer while maintaining the same ground clearance and storage capacity. I've got my new trailer design ~65% designed in SolidWorks, still waiting on some outside vendors to come up with the final portion of the design. I would love to make the "skins" out of some sort of composite, fiberglass? HDPE? Aluminum skins? Not sure yet. With composites comes the issue with sealing against moisture & dust. While my current trailer (85% fiberglass body) has been a great setup, another fiberglass tub is not readily available, and I hate to salvage that trailer (plus its likely going to a freind).
FWIW, I am completely sold on the solid axle and leaf springs if properly setup, with a major emphasis on proper setup. My trailer has ~10k miles on it... not a single issue with the handling of the leafs once I had it dialed in (proper loading techniques). I've had it on all sorts of terrain, sidehills, sand, jumps, etc... couldn't be happier. Add a sway bar into the mix and you've got something going IMO. If I was building a simple off-road trailer, I would go with leafs in a heart-beat.
Pardon my curiosity, why didn't you build the arms in this manner? Seems like there'd be more support this way.
Again, just curious!
Ash
