I absolutely hate the lack of climate control without the screen. I remember someone did it on here with an older LC. I’m willing to be the guinea pig for a 2016+ if someone can help me find the parts.
Either use VOICE control or (for me) i just increase / decrease temperature if i am not satisfied with fan speed (in AUTO mode). I use AUTO mode all day long.
Otherwise, good luck with the surgery. The radio is in the wrong place in above pic. It would not translate well to USA LC.
Never tried it…but my salesman when i bought it claims it…but you know…salesman are salesman. I just change temperature.Fan speed can be adjusted by voice control?
I had no idea. I just use it for calls. A quick look shows you can use it to turn climate controls on/off and adjust temperature. Both things you can do with one button, but can't adjust fan speed unfortunately.Never tried it…but my salesman when i bought it claims it…but you know…salesman are salesman. I just change temperature.
With the older model conversion done by a Mud user, he found a 4 zone manual unit, where most, like those pictured in this thread, are dual zone. Seems like it was a big project IIRC.A quick look through the EPC and some googling tells me:
- There are parts out there and available for the conversion
- and all you need is an electronics wizard, a parts guru and probably a good friend in the middle east
Nice. Do you have a link to a thread or write up?With the older model conversion done by a Mud user, he found a 4 zone manual unit, where most, like those pictured in this thread, are dual zone. Seems like it was a big project IIRC.
It isn't that. It is having to control everything through the touchscreen where the other physical buttons can still do "auto" but allows you to control without navigating through the touchscreen. I have a 23 Tundra, and it has separate controls that don't tie into the touchscreen, and it is great.What I find surprising is that people think manually controlling the temperature in your car is going to work better than setting the temperature and let the automatic system with many outlets do its job. Mind blowing, but then again I am an engineer therefore things in my world follow a logic.
Now in case the fan speed gets to low and you need a bit more air, just drop the temp button a few degree and that is it. Manual button on the 16+ is right there.
Oh well, good luck trying manual. Whatever floats your boat.
No, just remember reading it a few years ago. You can probably find it on search.Nice. Do you have a link to a thread or write up?
Found it for you:Nice. Do you have a link to a thread or write up?
Well, i have my car on auto climate control and set at 72 degr F front, 74 degr F rear.It isn't that. It is having to control everything through the touchscreen where the other physical buttons can still do "auto" but allows you to control without navigating through the touchscreen. I have a 23 Tundra, and it has separate controls that don't tie into the touchscreen, and it is great.
Can you point me in the direction of your steering wheel?!!I absolutely hate the lack of climate control without the screen. I remember someone did it on here with an older LC. I’m willing to be the guinea pig for a 2016+ if someone can help me find the parts.
I love the auto feature until my wife gets in the car and starts messing it all up. Smh.What I find surprising is that people think manually controlling the temperature in your car is going to work better than setting the temperature and let the automatic system with many outlets do its job. Mind blowing, but then again I am an engineer therefore things in my world follow a logic.
Touchscreen is required for wiper heater, if I want air only blowing out of the front vents, or just feet, etc. Sometimes I want the fan to be higher on defrost than what Auto provides as well. I agree that auto works well for most functions, but not all. My Tundra has "Mode" button that cycles through all the different options. That would have been a great option to have.Well, i have my car on auto and set at 72 degr F. Rear at 74 degr F.
I get in, start the car and that is it.... Only adjustment needed is maybe drop to 70 or 68 when the sun is shining full from the front or on a corner.
The buttons for that are right there.
What are you trying to do in the touchscreen?
forum.ih8mud.com
forum.ih8mud.com
So you are saying pressing <Front> and later back to <Auto> does not do the same?Touchscreen is required for wiper heater, if I want air only blowing out of the front vents, or just feet, etc. Sometimes I want the fan to be higher on defrost than what Auto provides as well. I agree that auto works well for most functions, but not all. My Tundra has "Mode" button that cycles through all the different options. That would have been a great option to have.
I'd have preferred that the controls were all physical for longevity purposes, as replacing a $3500 touchscreen to have HVAC controls is not a great solution.
The main reason I'd want a simple interface for HVAC is so I can put a standalone car stereo in the care, as Toyota's interface leaves a lot to be desired, and the Tesla style and other Chinese replacements all leave something to be desired, but I'm glad they're available in the event I need to replace my touchscreen at least. Putting in a good Alpine unit, and they sell a factory look option, would be great compared to the Toyota system.
