I have been using one for a couple of months. It works great and is very easy to use and set up.
Yes, it will estimate mileage with the present amount of fuel, as well as remaining hours of operation at the average consumption rate, etc. No it will no do service reminders. If you know the OBD-II system you can send raw commands across the bus with it and receive the resulting data.does this thing do anything useful? I really don't need another tachometer of water temp gauge.
Can it estimate remaining mileage with present amount of fuel? Can it be programmed for service reminders?
There's a setting to compensate for different tire sizes and/or gear ratios. With this configured, the displayed speed is corrected to your actual speed (and therefore, distance traveled is accurate too). There's also a calibration that is performed when you fill your tank, this calibrates the fuel consumption.
David;
Is this just OBD-2; or can it read 1994 LC OBD-1 system?
