Builds Another FJ68 Build (5 Viewers)
I can send u some mandarin and naval oranges. Have plenty of them.
I have not done anything with Vats. Talked to a tooner that knows the ends and outs of these and there is no way around the VATS. It has to be programmed out. On the car motors, you can run the bypass. I know multiple people that have passed with it programmed out. Depends on the ref. The only 2 things I am worried about are the VATS and exhaust manifolds. I had to use corvette to clear the frame. I know people that have passed with those. Will just research which ref.
IIRC if the exhaust manifolds are period correct and are EO# for the 5.3 you'll be fine. Can't help you with VATs. I went Erod C&C and glad I did.
J
Very very nice work. My kind of build.
Lizzard skin done and now applying the top coat.
Ok need help with this.
Is the body on, in that picture? If it isn't.. that would be why you got contact on the springs, bump stop, and tire....
The rear panhard is pulling the axle to its side...
Again, that's if the body is off the frame... once the frame it's loaded then it should center itself... i see you running the 3" bracket from delta... you might need to run a adjustable panhard to get it dead centered... i run a 5" bracket, and my non adjustable panhard is almost (level) 180° flat... and centered
Anyways, that's what i think is happening....
Rig is looking great...!!
