- Thread starter
- #281
my truck is back at budget exhaust and somebody no longer works there.
I wonder when I'll get the revised one? Probably in the mail with the reverse light wiringSo it looks like you guys have the original style intake horn ~3/4" taller than the revised low profile one I got?I'll post a pic of mine when I get home...
Be careful drilling the manifold. There is a inner wall right in the center of the flat spot which looks like the best place to drill.the way he measured the piping it's meant to use without the grid heater, or grid heater and that shorter intake horn. so mines wrong and there's enough play to make it work.
Got my glowshift gauge sort of installed, got trans temp and boost working! Everything looks good, trans temp is good and boost is good. I'll drill and tap the manifold later. That gauge is awesome, its got everything you need to install, probes and even enough wiring for the probes, all you need is the power/ground/acc/lights, very easy and for $180! it's like a sore dick you just cant beat it!!!![]()
