i have heard about putting marvel mystery oil to the rings during a rebuild also. Nice job.
Let me be the first to congratulate you on a job very well done! Thanks for taking us along for the ride!
Somebody needs to stop me!
This is getting out of hand now. The head didn't come back from the machine shop, so I've been delving further into the engine and it's stripped down to a block, crankshaft and pistons now. I think I've finally removed everything that needed service and now I'm starting to put things back on.
Before all of this started I planned to pull the oil pans to reseal the pan arches. They were leaking front and rear. Now was the time since I had easier access.
It took along time to clean the pans. They were both coated with a thick layer of old grease and oil.
The front was also leaking at the timing cover, so it came off too:
Since the cover was off, it was a simple procedure to replace the oil pump gasket and the front crankshaft seal.
The oil pump seal was dry, brittle and cracked easily when I pryed it out.
I had to use an impact driver to remove the screws on the cover. This job would have been a bitch if trying to go at it with everything still mounted on the truck.
I placed a new crankshaft seal in the cover and tapped it into place using the old seal.
Next step was to set the timing again. I aligned the bright link of the timing chain with timing mark on the crankshaft gear:
...and then did the same with the upper gear:
After the chain was aligned with the gears, I buttoned up the timing cover using some black FIPG.
josharre2000 - When you set the head back on the block, the timing gear and chain needs to be positioned as shown in this photo. I'll try to take more pics of the process of putting the cams back into position once I get the head back from the machine shop.
I would be interested in seeing a cost break down of this job so I know how much to save up before I tackle it.
Hey Craig, when you have some time, can you elaborate a little bit on how much extra work it took to pull and reseal the oil pans and the timing cover/oil pump?
I'm also interested in all associated gaskets, hoses, ect. parts pricing for this. I want to do the work myself.
I did a HG job on a Supra for about $300 with ARP head studs. The dealorship quoted me $3300.
Wire harness = PITA.
It doesn't have to be. Disconnect the plugs and roll the lower intake over to the DS. Secure with bungee. No unraveling and re-threading. Did it twice. The PITA with this way though is getting to the lower intake bolts with the head on.
IMHO YMMV
What do folks do to protect that wire harness??
ThemoTek heat tape from Summit or Jeggs or your local speed shop.
-B-
