-B- that is a nice guage and a clean install, did you document the install on the board somewhere? where did you put the sender?
are the bugs adjustable or preset?
RavenTai said:did you document the install on the board somewhere? where did you put the sender?
RavenTai said:are the bugs adjustable or preset?
Rich said:That fitting is cast aluminum. Find an expert welder who can deal with cast aluminum. Have another bung welded on. Drill & tap. Not a job for the average welder.
turbocruiser said:Or, better yet, is there a way to electronically erase that flat spot feature and create an accurate and linear gauge out of the factory gauge? I think this is what MTS was referring to but I do not know how to go about that, and I guess, all things equal I'd still rather have really accurate aftermarket gauge but use the existing temp sensor and wiring and whatsnot. Problem is I do not know if the existing temp sensor is the problem, or if its the gauge or both? Thanks guys.![]()
turbocruiser said:Great suggestions guys, what I want is both an EGT gauge and a coolant temp gauge. I'd like to find one that is rectangular and would fit in the spot under my cd-deck since Do you know of any rectangular gauge that would have those two functions?
mot said:This comes to mind:
Sorry if this is not very helpful.![]()
Mot
mts said:In *theory* it should be the gauge that is the issue. I have "linearized" the OEM gauge on my track car. You should be able to do it with the LC gauge as well if you want to dig into it. Unfortunately, I can't tell you which resistors to use. Someone I know did all the experimenting for me and I just followed his instructions when doing mine. The basic principles are here:
http://tinyurl.com/4x5fm
Perhaps there's an EE on this board that might want to dig into it?
Mike
turbocruiser said:Actually Mot, that is super helpful, thanks. I had a hard time with the Japanese though, can you tell me where to get this stateside? Thanks again, I think you are onto something!![]()
mot said:turbo,
I did a little more research and have found that a guy driving a '95 FZJ was using G'Reddy's 38φ (Product code: 16401638) and the retail price on their site shows about $30US.
Please confirm your hose diameter and confirm with G'Reddy US that they are accurate and that it would work on your rig.
HTH.
Good luck!
Mot
turbocruiser said:... and the correct corresponding celsius gauge is only like 55 dollars.
Beowulf said:The picture of the gauge that I posted (also used by Photoman) is a *lot* more than $55. I believe list is around $210; found new on eBay for ~$100.
-B-
