Alternator issues (3fe)
Alberta
Hey everyone,
So my alternator went boom in my 91 3fe, and accordingly i bought another alternator to replace it (denso 210-0177). After trying to install the new denso replacement (pictured right) I found out that the mounts are to small.
Does anyone know what I am supposed to do? I can’t find any alternator that is correct for it and there’s no part number on the old one (left side) to look it up.
I am getting the old one rebuilt regardless as I would like to have 2 on my hands for comvienence (I live in Canada).
Thanks.
Hey everyone,
Thanks.
this will solve your parts issue ........
it has the correct lower pivot tabs spacing u need
It looks like your new alternator is a 90 amp and the old is an 80 amp.
Based on part number also
I used the alternator from my FJ62 on my FJ80 when it was hard to get what I needed. To use the 90 amp, you need to modify the upper mount bracket and get or make a different lower mount. I'm going to make a jig and make my own lower mount when I get a little time so I can use the 90 amp I have sitting here. Or, good luck finding the parts. Toyota made them, but they're NLA.
for posterity's sake- I had this same issue after purchasing a new 90 A alternator from cruiser outfitters. An hour or two with a grinder and i was in business. I took off some of the new alternator and some of the mounting bracket.
