I agree dlines build tension and do not endorse the Sumo driving on pavement with CDL style, But I am doing 40-60 when everyone else is doing 25 so the traction is not good. The CDL keeps you from getting yanked to the side by hitting a drift or deep slush.
It is not hard to brake fast while not locking up the front or rear brakes with the CDL engaged making it easier to keep the truck strait if you start fish-tailing....at any speed!!!!
Push and skid? Its not a Bobcat.... UNLESS maybe your doing a 3-point turn on ice
Interesting experience on how a locked center diff can keep you from getting yanked by deeper snow on one side. I don't think the VC reacts quickly enough to make any difference to the tires slowing on one side and/or one end, but YMMV. I've been driving out of my 200 ft. driveway after last week's 30" snowstorm and the more locked I am, the more it wants to grab the snowbank sides. Low range AWD has been the best mode once I got it packed - fully locked was essential when I was drift busting out through 40 inches+ of snow.
CDL is the exact same thing as "part time 4wd" that used to come on most 4x4's, but it is there in the form of a switch - if you leave it on in bad weather, which is about the only place AWD is functional on a truck, then you really don't need AWD at all. There is a reason that "AWD" of "full time 4wd" has penetrated most of the so called "truck" markets. Your average driver is not going to know when the best time is to be engaged or not engaged, and it is better to have a computer and or mechanical functions doing the work (isn't VSC going to become mandatory? How bad does that suck if you can't turn it off?)
I still don't ever drive at speed in part time 4wd (CDL engaged). If I was willing to essentially ditch AWD in bad weather it would open up all kinds of t-case options such as the Atlas and the huge low gearing advantages that would come with it. An Atlas would be the same functional case as the 80 with CDL engaged, but you'd have a choice of some seriously low gearing. I can see zero reason to retain the stock case if you don't use it for AWD in snow and ice and you are interested in lower gearing. A Mark's crawler box is $3K plus gas tank mods. Ditch AWD functionality and a whole host of options may open up to you at better pricing - where it is a more complex issue is when you really want to retain AWD and have the lower gearing offroad.
In any case, CDL plus 7-pin mod creates an incredibly versatile system. Do both and figure out how to use them. If you see a lot of snow, go and get yourself stuck a bunch of times and figure out what works for each condition for your driving style.
Here are my general snow usage guidelines:
Any type of variable condition where some pavement is dry: AWD high, CDL off
Packed and icy snow at traffic speeds: AWD high, CDL off
Packed and icy snow where slow speed and additional gearing is advantageous: AWD low, CDL off
Moderate depth snow (6"-10" or so) at slower speeds where AWD may be slipping: Low range, CDL on
Moderately deep snow (10"-18") at slow speed: Low range, CDL on, rear locked
Completely unplowed snow (18"+) with drifts and no other vehicles on the road because they can't get out: Low range, CDL on, front and rear locked.
Also remember that you cannot disconnect the function of these systems from the tires you choose. Nokian, for example, is now designing their snow tires for use with TC and VSC systems. Aggressive offroad tires that excel in snow such as trxus MT's will work very differently to all terrains and dedicated snow tires in varying conditions. It is an area where you really do need to try different options in different conditions to find out what really works for you.
I have a neighbor with a '94 that is stock without lockers and Revos. His rig was useless in the last storm and would be useless in the 18" or so that is now on the ground in the current storm and the 12"+ that is coming over the next couple of days. I'd be loving a lot lower gearing with this kind of snow. It is all a system, not independent variables.
Nay
