AKUMA "THE DEMON" 60 BUILD (13 Viewers)
TRAIL TAILOR
Enabler
Supporting Vendor
Redding, California
Website
trail-tailor.com
Bought this 87 FJ60 from a local. Zero rust and in all around great shape. PO changed the color to white. I will change the paint color.
BUILD PLANS:
FRAME OFF-- Frame sent to powder
LS3 EROD 6.2L Cali smogged
Custom built 4L65E transmission with new Toyota tcase
FSR radiator with SPAL fan
Dobinsons IMS suspension
34" Toyos
New paint
Under belly strip and undercoating
80 axle swap with Eaton E-lockers front and rear, 4.10 gears
Trail Tailor 4340 CrMo rear axle shafts
Tom Woods driveshafts
Trail Tailor center console
Trail Tailor coil conversion - FRONT
Custom upholstery- panels and seat covers
New carpet kit with jute padding/heat barrier
Trail Tailor rear quarter storage panels
Trail Tailor tailgate storage lid
3M ceramic window tint
Trail Tailor armor- Front and rear bumpers
Trail Tailor sliders
All door and glass seals/weatherstrip
New windshield
New OEM mirrors
ComeUp winch
Stereo head unit and speakers
Hella horns
Speedhut triple gauges
Seals, gaskets, weatherstrip & runs all replaced
New marker lights, headlights, tailgate, turn and park lamps
New OEM door handles
Stripe kit
New grill and headlight covers
LED headlights
Jason
TT
Looks great. Out of curiosity, why not do the rear coils as well while you’re at it?
If it were a lower hp/torque motor I would (2F, 12HT, R2.8, 5.3). The coils in the rear are not as stable and the leafs handle the power way better. Even with an adjustable shock cranked up the body roll at hard throttle is too much for some drivers to handle. Especially with a 3" lift.
Ride with the IMS or MRR are comparable as well to the coils.
This is our preferred suspension with the LS3 now.
Great to know. Thanks for responding.
Soooooooo good!
Akuma is a roller again. Dobinsons IMS shocks, Trail Tailor tapered wire front coils, Dob rear leafs and anti-version shackles and pins.
Will finish up the steering tomorrow and then get the drivetrain set.
Will go to the storage shop until body is painted.
Jason
TT
Would you mind elaborating on this for those of us with LS's and your four corner coil setups? Is it just kicking ass around corners (body roll) to watch out for or is it more sneaky?
Thanks
